86 2,8L long box comanche X
finaly the bushwacker have cleared the customs and they should be here by monday or tuesday
and on top of that the GF is going home in quebec for the week so Ill have all my time to work on the truck
the plan is :
installing bushwackers
replacing TRE at pitman arm
installing whippers
iinstalling rearview mirror
change the oil in the rear diff
grind and paint diff cover
change the oil in the t-case
install the inside moulding (where the hood cable use to be )
clean the truck in and out
and then finaly :driving: comanche.gif
test drive
I can see the light at the end of the tunnel :beerhead: :beerhead:
  • Replies 151
GREAT read!
I've been a CJ guy since the late 60's. Still have 7 of them. I recently bought an 88 Comanche, 4.0, short box that is in amazing shape and will be driving it daily from here on out. I love this thing! I'm new to this forum so haven't had an opportunity to browse through much info yet..... I'm looking to install a lift so I naturally HAD to read your thread.
I don't plan to off-road this truck but want to lift it and run 33's with plenty of clearance. What are your thoughts on 4.5" lift vs 6.5" ? I've had real good luck with Skyjacker on the CJ's but want to do the right thing for my MJ when I lift it.
Also, where did you get your headliner?
BTW, Congrats on the birth of your son
the plan is :
installing whippers
test drive
fenders are in and GF leaving tommorow then 7 days at wrenching :jump:
and deal in progress 4x 35 for 5x33 see if the other guy wants mine :dunno:
if you got a pc and webcam near by you should do a live feed :D
yeah but that would take away valuable wrenching time :fool:
got a few things done today
took off the rear diff cover
rusty a bit time to clean it
then some paint
also took the gear stamping and still looking to confirm the 4.11 ratio since the tag is unreadable
if I'm doing this right the last 3 numbers are 37 and 9 so 37/9=4.111111111111111111111
hummmm got to love math :jump:
also time to finish the interior
installed the sun visor
and some new pedal covers
also changed the TRE at the pitman arm
new one on top
took off the 2 sided tape off the emblems
but the paint on them look's like crap
still wondering how to fix them before I put them on the truck
and also prep the tail light for a touch of paint to take off that chrome trim
finaly tommorow morning I'm starting on the bushwacker install
put the winter rubbers on for more room
and also picked up the goods....
2x 5 galons of 80x90 diff oil for :brows:
FREE
:bowdown: :bowdown:
but none of this would be possible without my good friend Stan who lent me his
propane heater for the garage
and that will be it for tonight
to be continued tommorow................................
wrenching again today
finish the rear diff
and yesterday I decided that the torx bolt had to go (striped 2 in the process)
and the local hardware store didn't have the right bolt size 5/16 x 1/2'' they only had 3/4''
so had to cut them
marked them all before
with the diff cover
all install ready to be fill
also painted the rear lights
I did the CAD thing and install the whipers to but forgot to take pics ( you can kinda see it with the tail lights)
right now just took a brake for lunch will be wrenching again this after noon
1st let me say amazing work since I last checked. 2nd check out this thead at the bottom I tell how I painted my Comanche emblems. Ill be doing this again on the 4x4 emblems I got not to long ago. So when do you think this will all be done and be on the road? What a truck it will be :clapping:
Brandon
Brandon
thank you Ill read a little tonight
and I'm hopping for saturday or sunday
instaling the bushwacker today
took longer then expected but done now
started on the passenger side
with the front one
then the rear one
moved on to the front driver one
dry fitting
the holes
the rear driver side was a little more tricky
I F*cked up some where and ended up dealing with this
so marked it up
and came up with this
with the extra flares molding
still in need of adjusment
and also painted the last piece of chrome
tailgate handle
next fill up the diffs and the t-case and the fuel lolll
and send her to the alignment shop
finaly the truck is done
just have to find a set of 32 or 33 for the summer
adding on little details like this one
will be painting the emblems tomorow and that will be the final thing
hope you guys enjoyed watching this truck get rebuilt
it will be my dd
now I just hope it will give me lots of milage so I can enjoy it even more
Dominic
well it seams that the truck doesn't wanna go on the road
Ive finished everything I had to do but when I double checked some things popped up
1- the flashers won't work properly
and the hazards don't work either
the pass one flashes like it has a burn one
and the driver one is burning the fuse each time
I've check the grounds in the driver fender
checked the sockets for all the flashers
2- the engine started making weird noise to
like I got a valve sticking or some like that
Ive posted a vid of it in the tech sect
hopefuly getting an answer soon so I can drive the s*cker
anyway here is a couple pics that I took while letting the engine warm up
these are from saturday night
watching tv and painting the emblems
ok the flasher in the front are working fine
and the rear pass to
found out I don't have voltage going to the rear driver one
I got voltage at the 157 conector but nothing at the back of the truck
so I'm guessing the wire is bad somewhere
I'll be replacing it soon and hopefuly that will fix it
also redid de G102 just to make sure
and I tought I had the wiring wrong when I did the XJ to MJ harness :thwak: but no its all good
the only thing I can think of that might have damage the wire is: those are the wire running along the door
and where it goes by 3 screws that hold the moulding before going under the truck
mechanic friend came buy tonight and he said most likely its the valve that needs adjustment
so Ill get on that some time before the end of the week
hopefully I'm not to retarded and f*ck things even more
and Ill try to take enough pics to do a DIY on it
more coming soon
Dominic
well I wanted to go for a drive today but my clutch slave said otherwise
I started the truck yesterday and drove it in the garage to work on the valves and this morning
I had a pudle of brake fluid under it
so I jumped in the truck and WHAT???????? no f*cking clutch pedal, straight to the floor
now I'm just about to set the truck on fire and dance around it and claim insanity
