86 2,8L long box comanche X
I should update now that I got time
I'm a proud dad of a baby boy born on the 15th of Novembre so that's why no update in a long time
now I got time and money to finish it
rear drive shaft and windshield
I was hopoing to get the windshield installed at home but to cold now for that ill have to get it towed over there .........
and the rear drive shaft will be done next week
shorten and balanced
the test drive should be in 2 weeks
A lot of glass companies will come to your house; do you not have that option?
they do but I need to heat the garage ...........its like -20 Celsius here right now
also getting the d-shaft done today 160$ later will see
  • Replies 151
finaly getting time and money to do this .......
I need to shorten my D-shaft
from this:
lwb,_2.8,____ax5-ax4,______np207,____d35= 54.75"
to:
lwb,_4.0,____ax15-ba10/5,__np231,___d35= 50"
and I have a 4.5" lift
from what I read, it should be an inch longer then the 50" indicated above
so shorten to 51"
right???
the answer to that is 50.25''
had it done this monday
fitted perfectly on
now time to change the oil in the diff and the t-case
putting winter tires on
adjusting the track bar
and that damn windshield
and it will be about time for a road test
hopefully the weather will be allowing me to work on the truck nutkick.gif hopefully above the 0°C
with the temperature giving me a hand right now.............. :huh???:
finaly above the 0°C
I was able to work on the truck without to much break to warm me up
got to open the diff (well the front one) to check the gears and change the oil
the gears look great no metal shrapnel in the oil
the oil was bad but changing it anyway
so I hope the rear diff will be as good as the front one
when and got my starter tested today and its burned
so Ill probably buy a set of brush on ebay and rebuild it unless its seaze
then itll be going to the JY and get me an other one
I don't wanna go that option right now there's like 3 feet of snow there :fs2:
so that's it for now and until the weekend
I'm building my budy's bassement this week (money for parts) and 2 hockey game on the schedule
so I won't have much time to work on the truck
have a good week
before you buy your kit know that youll have to change other parts to
track bar
brake lines
bump stops
and that's only a few
the next step after the install will be to check for proper gearing to run 33''
look for ''diff gears'' in the search option
youll gets lots of info on the site
well I went to the JY today
picked up a ''new to me'' starter
also got it tested and its good so will be installing it soon
when I get an answer for the wiring in the tech section
I also changed the starter relay to be sure I don't fry an other starter
should be done tommorow
I've changed:
the starter
the selenoid
the realy
the wires
the ignition switch before that
and still no start :fs2:
I'm so piss right now that I can't work on it no more
good thing I got a budy comming to take a look at it later on .........
made a trip to the JY this morning and came out with an ignition switch and a cpu for the truck
all that for 10$ :clapping:
and the new starter relay has came in to so I'm just about to go work on the truck
wish me luck, I hope its gonna start now
if not I got no idea what to change next
I think the ''new to me'' starter isn't good after all
I just tested it with an old battery an the selenoid engage but it won't spin
so Ill be on the hunt for a new starter :fs1:
lmao, i read it wrong,
thought starter was going and it didnt turn over.
good luck :thumbsup:
check your grounds
well I tried something today regarding my starter
I tried instaling a wire between the casing and the selenoid to the ground terminal of the selenoid
what happen?? as soon as I put the battery back on the starter cranks
so that's not the ground I'm looking for
Ill try something else later on
well 160$ down the drain :ack:
I went and bought a brand new starter
but at least the jeep start and run
so moving on to other stuff
I need to adjust the track bar because I think the jeep is still dog tracking
and I need to learn how to do an allingment ( if thats how it's spelled)
still waiting on my bushwackers
and the new steering wheel
more comming soon
