86 2,8L long box comanche X
  • Replies 151
thanks all
i got 3 set of rims with it including the one on the truck
there is a bit of rust on it but this is all fun and games with a project like that
I would like to know your input on what I wanna do with it
ill do the usual with
grand cherokee coils
SUA in the back
and swap the 2,8L for a 4L (HO probably)
or is there a better swap to do except the 4,3L ( cause I can't find any around here ) :wall:
my bigest question is more as any one of you shorten the bed and frame on a long box to shorten the wheel base :help:
oh yeah MORE PICS COMMING lollllll
shortening the wheelbase is very difficult compared to shortening the bed. you can cut around a foot out of the back of the bed, though.
a 4.0 swap requires a new hood, new front crossmember, new header/radiator supports, and maybe a little bit of massaging on the firewall.
a 4.3 is just a GHEY option. to each his own, but if you're going to put a 90 degree block in it, you may as well put a 350 in it since the mounts are all the same anyways.
here is some pics i just took when I came back from work
I cleaned the box out there was a plywood on the bed and I was afraid that there would be rust underneathbut its fine
slowly Ill start taking the interieur out to look what Ill will be against
I know the floor is rusted but I don't know how bad it really is
the front end looks ok
not to much exterieur rust expect on the bed
I will also take the engine out as soon as my friend is done with is engine jack
do you guys know a link for the frame stiffeners
Ill look at the DIY projects for ideas to do to the truck but if you have some you did with yours go ahead and tell me ill take everything I can get
TY
well here is what I found after taking the whole interieur out
its not nearly as bad as I tought aldo I was expecting some rust
(there is no such a thing as a rust free jeep lolllllllllll) :wall:
after working on trucks from quebec I was amaze to find how easy it is to work on a truck from alberta where they don't use salt on the roads so not everything is stuck in the rust
that is the driver side flooring woth some holes on the flooring and I know that ill have tu cut a lot more to install the new sheet metal
the second one is the passenger side witch is not as bad and I hope that after a good cleaning won't have to be replace
I laso have a couple questions for you guys
I bought an engine cleaner (degreaser) but it says on it to NOT put it on paint or I might damage it
so WHAT DO YOU GUYS USE ON THE ENGINE BAY to take the dirt and grease out ???
second question
what should I buy for flooring ?? premade flooring sheet or make my own??
  • 3 weeks later...
i finaly got to paint the engine bay
I'm getting ready for the transplant
I know I'm skipping some steps but the budget says otherwise
I'm still waiting on the floor pans and the rocker panel I ordered
I also started working on the rear end and started wire brushing the frame so I can paint it to
my helper isn't here this weekend so work takes a bit longer then expected
here is a pic of the engine bay painted
Image Not Found
I also went to crapytire this friday and bought the colour i was looking for
I know it won't be a pro paint job
this is the brand
this is what its gonna look like
its a little darker then the original paint almost like the ford colour
well I'm on a tight schedule is as to run as fast as I can
but I'm not pushing it to the point of skipping steps
well trying to do my best
I just hope it will look as good as my YJ
lolllll no this one
Image Not Found
Its the same one after 2 years at working on it
haven't made progress on the truck for the last few days
but today I just bought a 4.5'' lift from hell creek
for a very decent price and on top of that Tom is a very nice guy to deal with
and I also love the exchange rate 1.02 us to cad
can't wait to see it it will be here in a week or so
over the phone
yeah they do comanche 86 to 92
front coil and rear leafs
kit number RC-626S
actually if you wanna order give a call to tom is a great guy and if you have any question hell answer them right away
making good use of the beautifull sunny day
I finished painted the rear frame so this part is gonna be donne
looks good
I will probably attack the cab this afternoon and start taking care of the rusted floor
see how much work its gonna take
Did some of you guys put something on the inside fenders
I'm tempted to paint them to
they got no rust but don't wanna leave a chance for rust to start again
thanks all
by the way comments are appreciated :popcorn:
