Lenard Posted February 20, 2010 Share Posted February 20, 2010 Ok just a couple quick questions to make sure, in order to swap to a manuel in my 88 LWB AW-4 4x4, I need, 1. AX-15 (out of a 96 or newer in order to get external slave?) 2. Transfer Case with AX-15 (because spline count is different?) 3. A Shorter drive shaft, or cut mine down ( I want to go shorter right?) 4. and clutch pedal and assembly... Link to comment Share on other sites More sharing options...
kro10000 Posted February 20, 2010 Share Posted February 20, 2010 You might consider getting the ECU from a jeep with a stick, itll idle at lower revs, and you don't necessarily need a t case from behind an AX15, any later t cases from a 23 spline outupt AW4 work Link to comment Share on other sites More sharing options...
64 Cheyenne Posted February 20, 2010 Share Posted February 20, 2010 Trans mount TC linkage, tranny side is specific Renix flywheel, clutch assy Clutch master cylinder Pedal assy Pilot bushing Link to comment Share on other sites More sharing options...
james750 Posted February 20, 2010 Share Posted February 20, 2010 I know that some of the engine sensors are different (TPS for example). not completely sure, but you might need a different engine wiring harness as well. Link to comment Share on other sites More sharing options...
64 Cheyenne Posted February 20, 2010 Share Posted February 20, 2010 He can keep the same TPS from the AW-4, it'll idle a little higher is all. No harness changes with the exception that the AW-4 TCU will not be used or hooked up any more. The TCU is a stand alone system, no changes will need to be done with it unless you want to remove it Link to comment Share on other sites More sharing options...
whowey Posted February 20, 2010 Share Posted February 20, 2010 to a manuel Charlie??? Jerry??? Or my personal favorite.. Bat.. Or Labor??? Just having a bit of fun with you.... :D Link to comment Share on other sites More sharing options...
64 Cheyenne Posted February 20, 2010 Share Posted February 20, 2010 manual......Yeah that one. :rotf: Link to comment Share on other sites More sharing options...
Lenard Posted February 20, 2010 Author Share Posted February 20, 2010 Trans mount1.TC linkage, tranny side is specific 2. Renix flywheel 3. Pilot bushing 1. what does that mean? 2. there should already be a flywheel on my motor right? 3. why and what is that? Link to comment Share on other sites More sharing options...
freakjeep93 Posted February 20, 2010 Share Posted February 20, 2010 for your forst question I'm not sure, but for #2 you don't have a flywheel youve got a flexplate. flexplate=auto flywheel = manuel and i don't know the answer to #3 either . hpoe i helped abit Link to comment Share on other sites More sharing options...
64 Cheyenne Posted February 20, 2010 Share Posted February 20, 2010 1. Each transmission has a specific transfercase linkage bracket where it mounts to the transmission. 2.Auto transmission has a flex plate, kind if thin, the torque converter bolts to it. The torque converter acts like a flywheel, among other things in a auto trans. 3.There is a hole in the end of the crankshaft, it's not used in an auto, but on a manual transmission, the input shaft (pilot shaft) fits into the end of the crankshaft, there is a "pilot" bearing or bushing there to support the front of the pilot shaft. Like this: viewtopic.php?f=2&t=14321 Link to comment Share on other sites More sharing options...
