89comanchesleeper Posted January 22, 2010 Share Posted January 22, 2010 i have a 89 mj and i need a full cluster for it. thanks :waving: Link to comment Share on other sites More sharing options...
comanche87 Posted January 22, 2010 Share Posted January 22, 2010 are u looking for one with or with out a tach? if without wbkrazy has one!! Link to comment Share on other sites More sharing options...
Geonovast Posted January 22, 2010 Share Posted January 22, 2010 Forgot to ask in your other thread... Do you have an auto, or stick? If you have an auto and it has a column shifter, you're going to need to do some modification to get a full cluster in. There are no factory full clusters with the shift indicator in them. Link to comment Share on other sites More sharing options...
89comanchesleeper Posted January 22, 2010 Author Share Posted January 22, 2010 no its a stick, and i would like one with a tach. thanks. Link to comment Share on other sites More sharing options...
jimoshel Posted January 22, 2010 Share Posted January 22, 2010 PM sent Link to comment Share on other sites More sharing options...
89comanchesleeper Posted January 22, 2010 Author Share Posted January 22, 2010 i havent received any pms? Link to comment Share on other sites More sharing options...
Geonovast Posted January 22, 2010 Share Posted January 22, 2010 Look up at the top of the page, under the ComancheClub logo. It should say * Logout [ 89comanchesleeper ] * 1 new message Link to comment Share on other sites More sharing options...
89comanchesleeper Posted January 22, 2010 Author Share Posted January 22, 2010 lol nope. Link to comment Share on other sites More sharing options...
Geonovast Posted January 22, 2010 Share Posted January 22, 2010 Give it a little bit, from what I saw in another thread, the PMs are running a little slow tonight. Link to comment Share on other sites More sharing options...
89Tonto Posted January 23, 2010 Share Posted January 23, 2010 Geonovast said: Forgot to ask in your other thread... Do you have an auto, or stick? If you have an auto and it has a column shifter, you're going to need to do some modification to get a full cluster in. There are no factory full clusters with the shift indicator in them. 89comanchesleeper- sorry for the hijacking your thread... CRAP- there goes that plan. :doh: Is the a way around it or should I forget the swap? Any write-ups available on doing the modification to get a full cluster in? Link to comment Share on other sites More sharing options...
Wildman Posted January 24, 2010 Share Posted January 24, 2010 89Tonto..... Try this - viewtopic.php?f=9&t=14904&hilit=cluster+swap Link to comment Share on other sites More sharing options...
89Tonto Posted January 24, 2010 Share Posted January 24, 2010 Wildman said: 89Tonto..... Try this - viewtopic.php?f=9&t=14904&hilit=cluster+swap :cheers: Thank you!!!! Link to comment Share on other sites More sharing options...
jpnjim Posted January 24, 2010 Share Posted January 24, 2010 Wildman said: 89Tonto..... Try this - viewtopic.php?f=9&t=14904&hilit=cluster+swap I've been looking for this thread. :yes: :cheers: Link to comment Share on other sites More sharing options...
