2.5 question
pug
I have a 1990 2.5 tbi. I have a exauste leak from manifold area it only ticks when higher rpms so i am thinking it is gasket. My question is if it was a cracked manifold wouldnt it tick at all rpms.
Do you have all your exhaust bolts? The front stud on the 2.5/4.0 is notorious for working its way out and disappearing.
Yup, I'm missing the very front bolt for the exhaust manifold...it's a little loud, but doesn't seem to be leaking any exhaust fumes. I'm saying that for two reasons, one I'm not smelling any obvious exhaust fumes from under the hood, and two it passed VA inspection. I'd like to think that if it was leaking, or a serious repair, the inspector would've failed the truck...
Changed manifold gasket today and yes it was burned out on the bottom. I drove around all day no ticking parked it for about an hour started ticking again. Tighten everything down again drove around the block no ticking. I let it cool off went to get something to eat started ticking again. Haynes manual says to tourqe 22lbs. Is this correct or am i doing something wrong. Thanks
