random parts closeout prices
89eliminator
Thanks for the link. Just bought two rear shocks, Monroe Sensatrack 37029s to replace the XJ sensatracks I have installed. With the MT springs I'm riding around fully extended, hopefully this is a good replacement. Hard to find specs from manufactures about lengths and travel, but I think hornbrod is running these with his MT springs too without problems.
Also used discount code 23733171326659 (enter in the "where did you hear about us" section) and saved some more bucks! Came to $52.49 shipped for the pair.
No, I have OME shocks front and rear. The rear Monroe shock 37029 travel lengths are 14.375" - 23.000". The OME N40L shock I use (actually a ZJ shock) is 15.6" - 25.8". You may come up a little short w. the Monroes depending on your lift height, but I think they will be okay. :cheers:
Did you used to have them? Maybe I'm thinking of someone else. :dunno:
Anyway, the XJ shocks I have on now are the 37027 which are 12.75/20 compressed/extended. They worked great with the regular 4wd springs, but as soon as I put the MT springs in the additional height I got in the rear from the higher spring rate put them at fully extended just sitting in the driveway. They're not lift springs but the bed rides higher without weight in it, so I'm hoping the extra 3" from the MJ shocks will be enough. The 37029 are listed as 2x4 rear shocks, but there doesn't seem to be anything specific for 4x4. Does anyone happen to know the specs of the factory shocks that came with the MT (or towing) package?
They also had KYB5466 and 344090 shocks available but I can't for the life of me find any details about lengths and travel.
