Ridgerunner Posted November 27, 2010 Author Share Posted November 27, 2010 Well it has been a while since I was able to work on this, but now I have the time. My goal is to have it drving by Jan 1st (2011?) I wanted a rear axle that was a bit Stonger than the D35. Since I was going to have redo Spring mounts anyways I might as well upgrade th axle. Spent yesterday at the Pick & Pull Wrecking yard and Brought home a nice 98 Ford 8.8 with disc brake and 3.55 gears and ABS for ~$100. they had a 50% off sale :jump: I will need to work out some sort of conversion Circuit to get the correct number of pulses from the ABS sensor on the axle to the ABS on the jeep. My camera is Broken I hope to get it fixed and I will post some pics. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted November 27, 2010 Share Posted November 27, 2010 why do you want to keep ABS? why not just delete it and forget it? and...if you decide you don't want the tan interior, let me know...i could use those door panels.... -Pat Link to comment Share on other sites More sharing options...
Ridgerunner Posted November 27, 2010 Author Share Posted November 27, 2010 why do you want to keep ABS? why not just delete it and forget it? -Pat I want the ABS to work because it has it. I can't stand to have disconected non working features. Also since this is a DD and not going to be Wheeled It needs to have good road manners and the ABS is nice to have since we get alot of Black Ice and slippery frosen stuf here. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted November 27, 2010 Share Posted November 27, 2010 why do you want to keep ABS? why not just delete it and forget it? -Pat I want the ABS to work because it has it. I can't stand to have disconected non working features. Also since this is a DD and not going to be Wheeled It needs to have good road manners and the ABS is nice to have since we get alot of Black Ice and slippery frosen stuf here. I suppose. ABS has done nothing but screw me over...I don't like having it, but then again, I prefer full function rear brakes, too (no proportioning). Link to comment Share on other sites More sharing options...
Ridgerunner Posted November 28, 2010 Author Share Posted November 28, 2010 why do you want to keep ABS? why not just delete it and forget it? -Pat I want the ABS to work because it has it. I can't stand to have disconected non working features. Also since this is a DD and not going to be Wheeled It needs to have good road manners and the ABS is nice to have since we get alot of Black Ice and slippery frosen stuf here. I suppose. ABS has done nothing but screw me over...I don't like having it, but then again, I prefer full function rear brakes, too (no proportioning). I used to think that way also. Link to comment Share on other sites More sharing options...
Sappersoldier88 Posted February 23, 2011 Share Posted February 23, 2011 Hey Ridgerunner, I like the way the build is going. I'm picking up an MJ this weekend myself and it sound like we both have simliar interests on updating the look and work ability of our trucks. Wheres the pick and pull place you go to? Thanks! :wrench: Link to comment Share on other sites More sharing options...
Ridgerunner Posted March 9, 2011 Author Share Posted March 9, 2011 I go to the one in Clayton NC call LKQ on HWY 70 Link to comment Share on other sites More sharing options...
75sv1 Posted March 10, 2011 Share Posted March 10, 2011 Someone has done a Ford 8.8 swap and kept their ABS. I can't remeber whick forum. I'd do a Google search. Tom Edit, I think it was on MallCrawler. I think I have it printed out at home. If you don't find it, I'll see what I have. From what I remeber it was cutting out every other tooth in the ring sensor, and they there was some wiring involved. Link to comment Share on other sites More sharing options...
Ridgerunner Posted August 22, 2011 Author Share Posted August 22, 2011 it has been a while since I have done much on my MJ but I got to work on it this week end. I am repalcing the door hinges that are very worn with some I took off of a newer XJ I got one of the hinges done and 3 more to go. i used a ratchet strap to hole the door up in place Link to comment Share on other sites More sharing options...
RockinMJ Posted May 8, 2012 Share Posted May 8, 2012 Any updates? Link to comment Share on other sites More sharing options...
