Transmission Question, NP205
np205 is a transfer case not a transmission. a 205 is a good strong t-case. its only downfalls are its very heavy and it only has a 2:1 low range.
Oh, should I buy it? What transmission is in it? I bet he just looked under it and saw a number and gave it to me.
I'd much prefer the NP-231 that comes in a Jeep to the 205. That thing weighs infinite pounds and has a crappy low range ratio. Mate it to the manual trans of that era and you'll be doubling that infinity. I had the pair that came out of my 78 Bronco and there's no freaking way I was going to even try to support that kind of weight in my truck. :ack:
It sounds good on paper, but sucks in real life.
Buy it for what? Do you need a transmission, or a transfer case?
If you need a transmission, don't buy a transfer case.
combining an np205 transfercase with an np203 t-case nets 4:1 crawl ratio
After all the work of combining them, and especially if they really weigh infinity, you'd be better off just installing a 4:1 kit in a 231.
....except that 4:1 kit costs like a grand, and you can get both of these t-cases for less than $75 @ the junkyard.
