So how can I tell what year my Dana 30 is?
So I found this on the web and I have this on my axle tube:
610758-2 and 7 22 7 80
and it's very poorly stamped too.
FWIW the cover has a date in '95. Oh, and I noticed my U-joints aren't the same brand. :hmm: Which I guess is fine, seeing as I have to replace the one side anyway.
I have instaled gears/lockers bearings in D30's and 35's the D35 dident change much at all. The later ABS carriers 93-94 and newer had bigger bores that the axleshaft spider gears set in but thats about it. besides the C-clip non C-clip axles. The D30 carriers are the same from low and high pinion besides the gear ratio splits on both 30 & 35
98 xj non disco standard diff 3.55 gears
I also have the part nunbers for the axles.
I think this is also available through Dana's web site :hateputers:
:cheers:
