case5412 Posted November 27, 2009 Share Posted November 27, 2009 Well, I'm setting out my plan on paper then I will aquire the parts and begin building. Engine, Tranny, Axles, Tires. :rotfl2: I need a good choice for a turbo diesel engine swap. I was thinking the inline 6s from the old dodges. I'm going to make my build a little bigger than most, with higher torque and bigger tires. Budget is normal to low, I'm only barely insane. I'll be basing the tranny on the engine and so on. I have hardly any experience so please leave me a lot of reading material, thanks. :rotfl2: What do yall think about DIESEL ENGINE DONORS??? :hmm: :hmm: :hmm: :hmm: :hmm: :thumbsup: Link to comment Share on other sites More sharing options...
dasbulliwagen Posted November 27, 2009 Share Posted November 27, 2009 Theres only one thing to say about diesel engine swaps into an MJ.... EXPENSIVE!!!! The cummins 6 cyl is way to big to fit into an MJ without EXTENSIVE cab and unibody modification. And the axles needed for what you want will need extensive modification to work under an MJ. If you have little to no experience and few tools, and by tools I mean welder, sheet metal brake, plasma cutter, air compressor and wide selection of air tools, then this is not a project for you. I know it would be soo cool to do, but if you are on a strict small budget I can tell you that this is not going to happen. There are people ou there that have done a cummins 4 cyl swap, but again, it is extremely hard to do and requires tons of fab work. And it is really hard to find a 4cyl cummins donor... and if you do find one running, expect to pay more that 5 grand just for the motor... USED! Unless you have a ton of resources like a family owned truck junkyard with an attached metal shop, I don't see this happening. I hate to burst your bubble, but you need to be realistic about this, maybe build up an early first gen dodge cummins single rear wheel 3/4 or 1 ton. Then you can keep the MJ nice for around town or easier wheelin. Whatever you decide to do, we wish you luck and will be here to help you any way we can. Good luck! Link to comment Share on other sites More sharing options...
dasbulliwagen Posted November 27, 2009 Share Posted November 27, 2009 And let us know what the build date is on your truck... I see its a 92... some of us chrysler mechanics could tell you the exact day and hour it was made, and what options it originally came with and where it was originally sold. Post the last 9 digits of your VIN and I can get the info for you! Or you can PM them to me and Ill look it up! Link to comment Share on other sites More sharing options...
jimoshel Posted November 27, 2009 Share Posted November 27, 2009 Ditto on everything Dasbulliwagen said. Link to comment Share on other sites More sharing options...
case5412 Posted November 27, 2009 Author Share Posted November 27, 2009 Theres only one thing to say about diesel engine swaps into an MJ.... EXPENSIVE!!!! I hate to burst your bubble, but you need to be realistic about this, maybe build up an early first gen dodge cummins single rear wheel 3/4 or 1 ton. Then you can keep the MJ nice for around town or easier wheelin. Whatever you decide to do, we wish you luck and will be here to help you any way we can. Good luck! Yeah I am seeing it clearly now. A lot of headache and money and stress that is not worth it. Yeah it would be cool, but I am seeing how hard it would be. I'll have 13 months to get the truck where I want it and the Diesel engine is seeming impossible, well at least for me and for the time I'll have. I leaning more to building one frame up, in a couple of years. I would still like to see the Diesel engine builds, they would be cool to check out. Guess for this build I'll go the practicle route, seeing it's my first build and this is a brand new hobbie for me. I dream big and I will build one in a heart beat, if I only had the resources. :rant: :rant: :rant: :rant: :rant: :rant: :rant: I'll post up my VIN and MR Date tomorrow, I'm hitting the hay tonight. GNight Thanks again all Link to comment Share on other sites More sharing options...
CRF136N Posted November 27, 2009 Share Posted November 27, 2009 ... and if you do find one running, expect to pay more that 5 grand just for the motor... USED! quote] Almost worth it to be able to do this though :rotfl2: (ok, I'm sure everyone on here has seen this one a hundred times, but it always makes me smile, so watch it 101 times :banana: And of course this clip: :cheers: -James Link to comment Share on other sites More sharing options...
mvusse Posted November 27, 2009 Share Posted November 27, 2009 He's a member on here, and wheels it at JeepSkool occasionally. Met him once there. Even a 4BT is not an easy fit. He had to cut a hole in his hood to clear a second turbo when he went to a twin turbo set up. Transplanting a CRD out of a Liberty might be a though also, but with 13 months to get it done, I think you'd better forget about doing a diesel unless you have lots of spare time, and enough money to keep the build going without a break. Link to comment Share on other sites More sharing options...
NWPhotog Posted November 27, 2009 Share Posted November 27, 2009 ... and if you do find one running, expect to pay more that 5 grand just for the motor... USED! quote] Almost worth it to be able to do this though :rotfl2: (ok, I'm sure everyone on here has seen this one a hundred times, but it always makes me smile, so watch it 101 times :banana: And of course this clip: :cheers: -James I must be old. The first video looks like a waste of good/expensive rubber. The second looks like a course a stock Comanche could handle. The truck, now that IS cool! Link to comment Share on other sites More sharing options...
case5412 Posted November 27, 2009 Author Share Posted November 27, 2009 And let us know what the build date is on your truck... I see its a 92... some of us chrysler mechanics could tell you the exact day and hour it was made, and what options it originally came with and where it was originally sold. Post the last 9 digits of your VIN and I can get the info for you! Or you can PM them to me and Ill look it up! Here's the last 9 of my VIN, (NL142235), and my MR date is Sept 91. :chillin: :chillin: I know some specifics because I read on the forum that you could email chrysler and find out some specifics, and I did that. I got a pretty good make up of what the truck came stock with, it was wrong with one thing though. :clapping: :clapping: Link to comment Share on other sites More sharing options...
mvusse Posted November 27, 2009 Share Posted November 27, 2009 ... and if you do find one running, expect to pay more that 5 grand just for the motor... USED! quote] Almost worth it to be able to do this though :rotfl2: (ok, I'm sure everyone on here has seen this one a hundred times, but it always makes me smile, so watch it 101 times :banana: And of course this clip: :cheers: -James I must be old. The first video looks like a waste of good/expensive rubber. The second looks like a course a stock Comanche could handle. The truck, now that IS cool! A stock Comanche can handle that part, as I have done it when mine was still stock. Stock Cherokee also. I don't think he pushes it too hard, and I don't blame him. If my truck looked like that I'd be afraid of scratches, pin stripes and dings as well. I do push my truck, and it shows. I had to replace the driver's door 'cause it got too badly damaged, but before that I drove around with a big dent and scratch in it. Replaced both side mirrors twice now. I have dents in every part of the body including the roof and the frame, and the rear bumper looks like a pretzel. Some of those dents actually have names... Link to comment Share on other sites More sharing options...
kro10000 Posted November 27, 2009 Share Posted November 27, 2009 if you do end up wanting to do it, the diesels i am condisering are either the mercedes OM617 5 cyl diesel (literally indestructable), or the VW IDI turbo 1.9 Link to comment Share on other sites More sharing options...
dasbulliwagen Posted November 27, 2009 Share Posted November 27, 2009 Originally sold in Oklahoma City, OK In service date was January 28, 1992 with 18 miles on the odometer Build Date: September 26, 1991, hour 09 Last known owner whos name I won't give you lived on Tinker AFB Options as copied below: APAS Monotone Paint BGAS Power Front Disc/Rear Drum Brakes CUMS Mini Floor Console DMMS 3.07 Axle Ratio DRJS 175MM Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass JAZS Analog Instrument Cluster JCAS 85 MPH Primary Speedometer KWRS DESCRIPTION NOT AVAILABLE K3ZS DESCRIPTION NOT AVAILABLE LAPS Shift Indicator Warning Lamp LBCS Glove Box Lamp LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille MMCS Upper Door Frame Moldings MMGS Belt Moldings NAAS Federal Emissions NBKS EVAP Control System NF2S 18.5 Gallon Fuel Tank QE4S DESCRIPTION NOT AVAILABLE SFAS Standard Duty Shock Absorbers SGAS Rear Shock Absorbers TBCS Compact Spare Tire TBMS Tire Carrier Winch XBSS Pickup Box YAAS Build To U.S. Mkt. Specifications Z1AS GVW/Payload Rating 1AAS U.S. Dealer Retail 152S Zone 52-Kansas City Optional Equipment *C1 DESCRIPTION NOT AVAILABLE - SA DESCRIPTION NOT AVAILABLE ALAP SE Decor Group BARP 90 Amp Alternator BCDP 500 Amp Maintenance Free Battery CBAP Straight Back Bench Seat CKAP Carpets - Floor and Cargo Area DBBC All Manual Transmissions DDQ 5-Speed Manual Transmission ERH 4.0L I6 Power Tech Engine GFD Rear Sliding Window GRZP Left Remote Mirror GSZP Right Remote Control Mirror GTZP Manual Remote Mirrors HAA Air Conditioning JHAP Var Intermittent Windshield Wipers JJAP Cigar Lighter KERP DESCRIPTION NOT AVAILABLE MBJP Black Front Bumper MDA Front License Plate Bracket MHAP Black Windshield Moldings MMKP Body Color Drip Trough Molding PE4 DESCRIPTION NOT AVAILABLE RAAC All Radio Equipped Vehicles RAFP AM/FM Cassette Radio RCDP 4 Speakers SBAP Power Rack and Pinion Steering SCGP Leather Wrapped Steering Wheel SUA Tilt Steering Column TMWP P215/75R15 OWL All Terrain Tires TZAP Goodyear Brand Tires WJNP 15 Aluminum Wheels WLZC All Aluminum Wheels YGEA 5 Additional Gallons of Gas Z01P Rear Spring Group I Z58P Left Front Spring Group Viii Z78P Right Front Spring Group VIII 2TCA Customer Preferred Package 2TC 25C Customer Preferred Package 25C 3VNA Customer Preferred Discount 4EA Sold Vehicle 4M1P Retail to Bid Diversion Tracking 4UAA SCA Tissue North America LLC Some of the codes have been recycled and thus show something that they no longer stand for, like rack and pinion steering. Link to comment Share on other sites More sharing options...
CRF136N Posted November 27, 2009 Share Posted November 27, 2009 I must be old. The first video looks like a waste of good/expensive rubber. The second looks like a course a stock Comanche could handle. The truck, now that IS cool! Ugh, your killing me with the criticism!!! :shake: OK, so yes...a waste of good/expensive rubber did cross my mind too, HOWEVER, think outside the box a bit...are you telling me you get no fun out of stabbing a throttle to the floor, and have a 4x4 COMANCHE (of all things) throw you back in your seat, holding on for dear life as it reaches 0-60 in seconds, all while getting 25+ miles to the gallon, at WORST!!!? :brows: C'mon, usually not needed I'll admit, but it sure is nice to have that on reserve for when you do And my subaru could damn near do that course, but the diesel sound out of an MJ is what makes it so awesome...So if this guy is a member on here, WHY ISN'T HE CHIMING IN!!! Does anyone have a link to his build, on here or elsewhere?...I want to see a picture of every square inch and know EVERYTHING about that truck as I WILL someday build my own 4bt MJ. I just gotta find the money for it :hmm: :cheers: -James Link to comment Share on other sites More sharing options...
freakjeep93 Posted November 28, 2009 Share Posted November 28, 2009 i think mvusse meant heas a member of jeepskool. i think I'm know n to be wrong Link to comment Share on other sites More sharing options...
mvusse Posted November 28, 2009 Share Posted November 28, 2009 He is a member of JeepSkool as well, but what I meant is he is a Comanche Club member. http://www.comancheclub.com/forums/memberlist.php?mode=viewprofile&u=3219 Link to comment Share on other sites More sharing options...
NWPhotog Posted November 28, 2009 Share Posted November 28, 2009 Ugh, your killing me with the criticism!!! :shake: OK, so yes...a waste of good/expensive rubber did cross my mind too, HOWEVER, think outside the box a bit...are you telling me you get no fun out of stabbing a throttle to the floor, and have a 4x4 COMANCHE (of all things) throw you back in your seat, holding on for dear life as it reaches 0-60 in seconds, all while getting 25+ miles to the gallon, at WORST!!!? :brows: C'mon, usually not needed I'll admit, but it sure is nice to have that on reserve for when you do And my subaru could damn near do that course, but the diesel sound out of an MJ is what makes it so awesome...So if this guy is a member on here, WHY ISN'T HE CHIMING IN!!! Does anyone have a link to his build, on here or elsewhere?...I want to see a picture of every square inch and know EVERYTHING about that truck as I WILL someday build my own 4bt MJ. I just gotta find the money for it :hmm: :cheers: -James Must be a difference in age. When I watch the first one I just think what a fool for ruining his tires. Link to comment Share on other sites More sharing options...
case5412 Posted November 29, 2009 Author Share Posted November 29, 2009 Originally sold in Oklahoma City, OKIn service date was January 28, 1992 with 18 miles on the odometer Build Date: September 26, 1991, hour 09 Last known owner whos name I won't give you lived on Tinker AFB Thank you very much this is a big help. I'm pretty sure that I know the old owners of the truck I have a copy of the original title, and I'm the one that lives on Tinker AFB. Thank you again for the information, I'll be printing this out and putting in my papers. Heck yes :typing: :typing: Link to comment Share on other sites More sharing options...
case5412 Posted November 29, 2009 Author Share Posted November 29, 2009 Originally sold in Oklahoma City, OKIn service date was January 28, 1992 with 18 miles on the odometer Build Date: September 26, 1991, hour 09 Last known owner whos name I won't give you lived on Tinker AFB Thank you very much this is a big help. I'm pretty sure that I know the old owners of the truck I have a copy of the original title, and I'm the one that lives on Tinker AFB. Thank you again for the information, I'll be printing this out and putting in my papers. Heck yes :typing: :typing: Hey can you do this cool information look up for my MK also??? here's my VIN is you can, 8D703775. It was made in eary 08. :banana: Link to comment Share on other sites More sharing options...
dasbulliwagen Posted November 29, 2009 Share Posted November 29, 2009 Originally sold in Oklahoma City, OKIn service date was January 28, 1992 with 18 miles on the odometer Build Date: September 26, 1991, hour 09 Last known owner whos name I won't give you lived on Tinker AFB Thank you very much this is a big help. I'm pretty sure that I know the old owners of the truck I have a copy of the original title, and I'm the one that lives on Tinker AFB. Thank you again for the information, I'll be printing this out and putting in my papers. Heck yes :typing: :typing: Hey can you do this cool information look up for my MK also??? here's my VIN is you can, 8D703775. It was made in eary 08. :banana: In-Service Date: March 27, 2008 In-Service Odometer: 5 Miles Build Date: March 10, 2008, Hour: 16 Selling Dealer: 44339 - PATTERSON DODGE CHRYSLER JEEP Sales Type: 1 - DIRECT RETAIL City: WICHITA FALLS State/Province APAS Monotone Paint BANS 120 Amp Alternator BCPS 525 Amp Maintenance Free Battery BGES Brake Assist BNBS Electronic Stability Program BNSS Electronic Roll Mitigation BRFS Anti-Lock 4-Wheel-Disc Brakes CAXS Rear 60/40 Split Recline Seat CDHS Driver Height Adjuster Seat CDLS Manual Driver Lumbar Adjust CDWS Frt Pass Forward Fold Flat Seat CG1S Advanced Multistage Front Air Bags** CJ4S Supp. Side Curtain Frt/Rr Air Bags CKCS Floor Carpet CLXS Luxury Front Rear Floor Mats CL4S Ultrafloor Vinyl Load Floor Covering CMAS Heated Front Seats CSRS Passenger Assist Handles CUFS Full Length Floor Console CVKS Sliding Armrest CVNS Folding Flat Load Floor Storage GAMS Solar Control Glass GEGS Deep Tint Sunscreen Glass GFAS Rear Window Defroster GMLS Liftgate Door w/Fixed Glass GNKS Rear View Auto Dim Mirror GNUS Sliding SunVisors w/Mirrors GTNS Power Mirrors, Fold-Away GXRS Keyless Entry GXXS Sentry Key Theft Deterrent System HAAS Air Conditioning JAYS Instrument Cluster w/Tach JBDS Instrument Panel Satin Silver Bezel JCBS 120 MPH Primary Speedometer JHAS Var Intermittent Windshield Wipers JHBS Rear Window Wiper/Washer JJFS Single Low Note Horn JKPS 12V Auxiliary Power Outlet JKVS 115V Auxiliary Power Outlet JKYS Power Accessory Delay JPDS Power Windows, Driver One-Touch JPHS Speed Sensitive Power Locks LAHS Outside Temp Display in Odometer LAZS Vehicle Information Center LCDS Map/Dome Reading Lamps LCKS Front Dome Lamp LCRS Interior Removable/Rechargeable Lamp LMAS Halogen Headlamps LNJS Fog Lamps MCXS Body Color Fascias w/Bright Insert MHES Lower Bright Bodyside Molding MNAS Black Door Handles MPLS Black-Out Tape MPNS Body Color Liftgate Applique MSUS Limited Edition Badge MVDS 4X4 Badge MWES Side Roof Rails MWSS Jeep Badge NF6S 13.5 Gallon Fuel Tank NHMS Speed Control QGJS Jeep Green Met. Clear Coat RCDS 4 Speakers RDDS Fixed Long Mast Antenna REFS AM/FM Compact Disc Radio RSAS Sirius Satellite Radio SBPS Performance Steering SCCS Leather Wrapped Steering Wheel SDCS Touring Suspension SHCS Rear Stabilizer Bar SUAS Tilt Steering Column TBCS Compact Spare Tire TT1S P215/55R18 BSW AS Perf Tires WPWS 18X7.0 Aluminum Wheels XGDS Universal Garage Door Opener XGMS Tire Pressure Monitoring Display XGRS Rear Seat Heat Ducts XJGS Non Locking Fuel Filler Cap XSCS Bright Interior Accents X81S Instrument Panel Parts Module X84S Front Suspension Parts Module X85S Rear Suspension Parts Module X87S Power Train Parts Module X88S Tire Wheel Parts Module X89S Front Suspension Damper Parts Module X91S Rear Suspension Damper Parts Module YAAS Build To U.S. Mkt. Specifications Z1AS GVW Rating - 4435# 1AAS U.S. Dealer Retail 163S Zone 63-Dallas 5IRS MK-Vehicle Family 5I4S Four Wheel Drive (4WD)/(4X4) 5I8S Left Hand Drive (LHD) 5RES 2008 Vehicle Specifications 5ZCS Price Class P 5ZRS Four Door (Compass) 594S Vehicle Order Tracking 6USS U.S. Specifications Label 644S Texas Ship to State Code 944S Texas Sold to State Code Optional Equipment Code Description Code Description Code Description *AL Leather Trimmed Bucket Seats - KA Pastel Pebble Beige DD7 5-Speed Manual T355 Transmission ED3 2.4L I4 DOHC 16V Dual VVT Engine LACP Illuminated Entry MDAP Frt License Plate Attachment Screws NAA Federal Emissions PGJ Jeep Green Met. Clear Coat RDZP Steering Wheel Mounted Audio Ctrls TZFP Firestone Brand Tires X9AP For More Info, Call 888-539-7474 X97P 1-Year Service Provided by SIRIUS YG6A 6.2 Additional Gallons of Gas ZFEP Spring - Left Front ZFTP Spring - Left Rear ZUEP Spring - Right Front ZUTP Spring - Right Rear 2DFA Customer Preferred Package 2DF 25F Customer Preferred Package 25F 4EA Sold Vehicle 4H4 Special Scheduling Condition VII Link to comment Share on other sites More sharing options...
case5412 Posted November 29, 2009 Author Share Posted November 29, 2009 Originally sold in Oklahoma City, OKIn service date was January 28, 1992 with 18 miles on the odometer Build Date: September 26, 1991, hour 09 Last known owner whos name I won't give you lived on Tinker AFB Thank you very much this is a big help. I'm pretty sure that I know the old owners of the truck I have a copy of the original title, and I'm the one that lives on Tinker AFB. Thank you again for the information, I'll be printing this out and putting in my papers. Heck yes :typing: :typing: Hey can you do this cool information look up for my MK also??? here's my VIN is you can, 8D703775. It was made in eary 08. :banana: In-Service Date: March 27, 2008 In-Service Odometer: 5 Miles Build Date: March 10, 2008, Hour: 16 Selling Dealer: 44339 - PATTERSON DODGE CHRYSLER JEEP Sales Type: 1 - DIRECT RETAIL City: WICHITA FALLS State/Province Thank you very much. I'm from 2 hours west of you in NC. lol Link to comment Share on other sites More sharing options...
Johnmastin86mj Posted November 17, 2015 Share Posted November 17, 2015 if you do end up wanting to do it, the diesels i am condisering are either the mercedes OM617 5 cyl diesel (literally indestructable), or the VW IDI turbo 1.9 Can you share more info on the Mercedes motor please.. Link to comment Share on other sites More sharing options...
Megadan Posted November 17, 2015 Share Posted November 17, 2015 How much power do you want? How complicated or expensive do you want to swap to be? The 4bt cummins, while viable, is a very large and heavy engine(800lbs) that requires at least 5-6" of lift to be a truly viable option as it's an incredibly tall motor. stock they make OK power and torque, and being entirely mechanical means they are easy to install. The real issue comes down to the driveline (after all the previous is taken care of) as the stock AX-15 will be ok behind a stock 4bt and even a mild one, but at the 200hp level they start putting out well over 500lb-ft.The Mercedes Diesels are nice. not too heavy and run nice. They have the downsides of being not that fuel efficient, especially for a diesel, and can get rather expensive rather quickly. Depending on where you live they may not be the easiest to find either.My personal favorite, and eventual planned swap is something much smaller than either, a 1999-2003 VW 1.9TDI/ Before you laugh consider it weighs 180lbs less than the jeep 4.0L. And it is not a space hog like the other two. While it is electronic (complicated) there are some resources out there that really explain the wiring for swaps. It's stock power output is not overwhelming (90hp and 155lb-ft) they are easy to hop up and can push about 150hp on a stock turbo, and near 200hp with a small upgrade while making at or over 300lb-ft. without reliability being a concern. Will it be fast? No, but with upgrades it will at least be as peppy as a stock 4.0 and even a mild stroker. The real advantage is lightniss and fuel econ. Most swapped pickups (Toyotas) average 30-38mpg. There is a company that sells a complete adapter setup with flywheel and other parts for a decent price too. The best part, IMHO, is that it would work perfectly with the gearing already used with the 4.0L because they operate across a 5000rpm rev range.In any case, if you are after huge torque to impress your buddies, obviously the little 1.9 TDi isn't for you, but considering Jeep put a 2.1L 4cyl diesel in these trucks once, it's not too far off the mark. Link to comment Share on other sites More sharing options...
buckwheat Posted November 18, 2015 Share Posted November 18, 2015 I would be interested in any links you have to more info. I know of the Coty motor swap, but that is rather expensive. Although 30+ mpg sounds awesome. Link to comment Share on other sites More sharing options...
johnj92131 Posted November 18, 2015 Share Posted November 18, 2015 If you want more information on the VW TDI swap into a Jeep, check out the TDIClub TDI conversions section: http://forums.tdiclub.com/forumdisplay.php?f=63 Lots of jeep conversions there as well as a ton of Toyota truck TDI conversions, and lots of others. My 96 Passat TDI puts out 162 hp and 285 lb/ft with just larger injectors, a bit bigger - but stock turbo and a chip tune. I got 45 mpg on a 9700+mile cross country trip in September. Oh, and I detuned the engine from 172 hp and 313 lb/ft of torque just to keep the smoke down. Link to comment Share on other sites More sharing options...
johnj92131 Posted November 18, 2015 Share Posted November 18, 2015 The other engine you might want to look at would be the 2.5 diesel found in Jeeps in Europe. This is NOT the Renault diesel, rather built by VM and is a close relative of the 2.8 diesel sold here in the 2005-6 Liberty. The good thing about this engine is the factory has done all the engineering for you if you import one of these with the trans and everything. About as close to bolt in as you will get with a diesel swap. Not saying cheap or easy. Just saying all the factory parts are in europe and sold by by Jeep. Link to comment Share on other sites More sharing options...
