possum Posted November 16, 2009 Share Posted November 16, 2009 Being that these trucks are older than most the adjusting sleeve on my tierod is a liitle hesitant to turn. Is it alright to use a pipe wrench on the adjuster to get it to turn or will this damage other parts? I just replaced my outer tie rod and don't want to pay $50 to just re center my wheel. Any other tips would be greatly appreciated. Link to comment Share on other sites More sharing options...
jimoshel Posted November 16, 2009 Share Posted November 16, 2009 Soak the threads with a good penetrating oil. Not WD40. let set a couple hours. Prudently applied a pipe wrench shouldn't hurt. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted November 16, 2009 Share Posted November 16, 2009 Use whatever will work for you, shouldnt hurt the ends unless they are bad already, and if you break something, then at least youll have an excuse to get a new one!, And you know, the sleeve you need to adjust is the one on the arm connected to the steering box arm. That one will center your steering. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 16, 2009 Share Posted November 16, 2009 possum said: Being that these trucks are older than most the adjusting sleeve on my tierod is a liitle hesitant to turn. Is it alright to use a pipe wrench on the adjuster to get it to turn or will this damage other parts? I just replaced my outer tie rod and don't want to pay $50 to just re center my wheel. Any other tips would be greatly appreciated. You do not adjust the sleeve on the tierod to center the steering wheel, that's for toe. You adjust the sleeve on the draglink. Link to comment Share on other sites More sharing options...
Eagle Posted November 16, 2009 Share Posted November 16, 2009 I had to use a pipe wrench when I took the lift out of my '88 MJ. The sleeve was rusted pretty solidly in place. Apply liberal quantities of PB Blaster daily for a week before you attempt to adjust. (And remember to loosen the clamps ... :doh:) Link to comment Share on other sites More sharing options...
possum Posted November 17, 2009 Author Share Posted November 17, 2009 Straight as an arrow now. Once I got it moving (which didn't take too much force) it was a piece of cake. And PB Blaster is good stuff but Kroil is much much better. :chillin: Link to comment Share on other sites More sharing options...
Eagle Posted November 18, 2009 Share Posted November 18, 2009 possum said: And PB Blaster is good stuff but Kroil is much much better. :chillin: I absolutely agree, but you can buy PB Blaster about anywhere, and Kroil is a lot harder to find for most people. Link to comment Share on other sites More sharing options...
possum Posted November 18, 2009 Author Share Posted November 18, 2009 True enough. I get mine through work. Link to comment Share on other sites More sharing options...
jimoshel Posted November 18, 2009 Share Posted November 18, 2009 I would like to get a can, or two of that Kroil. If anybody can send me any I will pay all costs incurred.J Link to comment Share on other sites More sharing options...
comanche09 Posted November 18, 2009 Share Posted November 18, 2009 Anyone remember which way to turn to adjust the wheel left or right? Thanks Link to comment Share on other sites More sharing options...
LoTGoD Posted November 18, 2009 Share Posted November 18, 2009 jimoshel said: I would like to get a can, or two of that Kroil. If anybody can send me any I will pay all costs incurred.J Just order as much as you like! http://www.kanolabs.com/ Link to comment Share on other sites More sharing options...
possum Posted November 18, 2009 Author Share Posted November 18, 2009 I had to turn the adjuster towards the rear of the truck to move the wheel to the right. Link to comment Share on other sites More sharing options...
navigator Posted November 18, 2009 Share Posted November 18, 2009 I read an article somewhere where a guy had done a study and 50/50 ATF and Acetone was by far the best you could get for the money. I know wd-40 was at about the bottom of the list, PB about mid way, Kroil was at the top but the mix was above it. Seems there was one better but it was really expensive and maybe not even publicly available. Link to comment Share on other sites More sharing options...
veritas4156 Posted November 19, 2009 Share Posted November 19, 2009 I actually keep a bucket of leftover ATF and brake fluid and the ends of cans of PB blaster and the like as a parts/tool lubricator/cleaner/deruster. Works better than any other stuff I've ever used. If I have to loosen some really rusty stuff on a car, I grab a solo cup and scoop some of that nasty bucket up and pour it on whatever needs to be loosened on the car and I let it soak for a couple of hours. Normally does the trick quite well. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 20, 2009 Share Posted November 20, 2009 comanche09 said: Anyone remember which way to turn to adjust the wheel left or right? Thanks If you are under the truck on the drivers side and sight down the drag link, if you turn the adj. sleeve cw the steering wheel moves cw. Link to comment Share on other sites More sharing options...
