biggwheels Posted November 4, 2009 Share Posted November 4, 2009 would the dash from a 93 cherokee fit in an 89 comanche???? Link to comment Share on other sites More sharing options...
Geonovast Posted November 4, 2009 Share Posted November 4, 2009 The dash or the gauge cluster? Physical dash, yes. Gauge cluster, no. You'll need one from an 86-90. Link to comment Share on other sites More sharing options...
XXLMJ Posted November 4, 2009 Share Posted November 4, 2009 If you have an 88 MJ with dummy lights and no gauges, would Gauges from a 90 XJ fit? And is it a plug and play thing or do you have to cut wires? Link to comment Share on other sites More sharing options...
maddzz1 Posted November 4, 2009 Share Posted November 4, 2009 If you have an 88 MJ with dummy lights and no gauges, would Gauges from a 90 XJ fit? And is it a plug and play thing or do you have to cut wires? Should be a direct swap. Just plug in the two connectors ond the speedo cable to the new one. You just have to swap the oil and temp senders from the ones for the idiot lights to the ones for gauges. Link to comment Share on other sites More sharing options...
88SporTruck Posted November 5, 2009 Share Posted November 5, 2009 In what year did they switch from a cable operated speedo to an electronic one? 1991? Link to comment Share on other sites More sharing options...
Geonovast Posted November 5, 2009 Share Posted November 5, 2009 In what year did they switch from a cable operated speedo to an electronic one? 1991? Yessir. Link to comment Share on other sites More sharing options...
greg Posted November 13, 2009 Share Posted November 13, 2009 :Canadaflag: New to site, planning a cluster swap, i have 88 mj 4.0 5 speed, with gauges no tach, "original owner" for a 89 cherokee 4.0 cluster with tach. straight swap? thanks. will properly introduce my jeep to site later i find my way around. thanks Link to comment Share on other sites More sharing options...
Eagle Posted November 13, 2009 Share Posted November 13, 2009 :Canadaflag: New to site, planning a cluster swap, i have 88 mj 4.0 5 speed, with gauges no tach, "original owner" for a 89 cherokee 4.0 cluster with tach. straight swap? thanks. will properly introduce my jeep to site later i find my way around.thanks If you already have gauges, the upgrade to the cluster with the tach is literally plug-n-play. The tach wiring is already there, and since most 88-90 clusters with tach are from vehicles with the 6-cylinder engine, you don't have to worry about recalibrating a tach from 4-cyl to 6-cyl. No need to replace senders if you already have gauges. And if you want your odometer to read correctly, since you already have the trip meter you can just swap speedos in the cluster, or perhaps swap odometers between the two clusters if the font style is different between the two speedos. Link to comment Share on other sites More sharing options...
greg Posted November 13, 2009 Share Posted November 13, 2009 :Canadaflag: Thanks, i was hoping that was all i had to do, time to give my old Comanche a little upgrade, thanks for the tips also. i think there's a trick in releasing the speedo cable too, push in and turn? i'll be careful. Link to comment Share on other sites More sharing options...
comanche09 Posted November 13, 2009 Share Posted November 13, 2009 :Canadaflag: New to site, planning a cluster swap, i have 88 mj 4.0 5 speed, with gauges no tach, "original owner" for a 89 cherokee 4.0 cluster with tach. straight swap? thanks. will properly introduce my jeep to site later i find my way around.thanks I have the same truck as you and had the gauge/no tach cluster too... If you want to retain your "old school" blue gauge font (much prefer), try to locate a full gauge/tach cluster from an 87 XJ. 1987 4.0L was the only year where the old school fonts are plug and play with 88-90 Renix 4.0 rigs. 86 and below cluster does not work. The newer Japanese font looks out of place in our trucks IMO. I got mine from an '87 Wagoneer 4.0L. Good luck! Link to comment Share on other sites More sharing options...
greg Posted November 13, 2009 Share Posted November 13, 2009 thanks for the infor comanche9, Looking at a removed instrument cluster, but the Tach is showing 1800 rpm's, no good? should it be 0?, all other's i seen shows 0, i'm thinking don't buy. any thoughts? thanks :Canadaflag: Link to comment Share on other sites More sharing options...
88XJSport Posted November 13, 2009 Share Posted November 13, 2009 thanks for the infor comanche9, Looking at a removed instrument cluster, but the Tach is showing 1800 rpm's, no good? should it be 0?, all other's i seen shows 0, i'm thinking don't buy. any thoughts? thanks :Canadaflag: Thats Ok. All the blue faced clusters do that. When you turn the key on, right before you start the engine, the tach should jump down to zero. Link to comment Share on other sites More sharing options...
