Broke down
EmJay89
If you use the 231, there's no more using 4wd on dry pavement. You'll lose the fulltime feature that the 242 affords.
I think the 242 is a bit longer than the 231. But I'm straining the brain here and I might be wrong. :dunno:
I was in the jeep when it went out, i thought for sure it was the tranny. Did a search when i got home and came up with the bolts in the flexplate came loose. WOW was i wrong. Looks like his MJ just turned into a donor for the DD. :D
