Pete M Posted September 11, 2009 Share Posted September 11, 2009 I don't know how long a manual trans lasts with water contamination, but I know low long a Peugeot will last with no fluid whatsoever. :D about 20 miles before I could no longer shift cause it finally got stuck in 3rd. then another 5 or 6 miles to get home. the dang thing blew a hole out the side while on the freeway traveling home. :fs1: Link to comment Share on other sites More sharing options...
Lenard Posted September 12, 2009 Share Posted September 12, 2009 i prefer stick, i like being in control :D and when you have loud exhaust you can make it sound better with a stick :brows: one day hopefully i can afford to put a AX-15 in mine Link to comment Share on other sites More sharing options...
jpdocdave Posted September 12, 2009 Share Posted September 12, 2009 no trans will "last" with water in it, but a manual will last long enough to change it after wheeling usually, unless you drove 300 miles in your wheeler to get there. its just not a complete death sentence is all i was saying. having both auto and manual transes apart for repair, i'll tell ya, there's maybe what 50 parts in a manual, and hundreds if not thousands in an auto considering solenoids, check balls, valve body sun gears, planetary, clutches, and all that crap. Link to comment Share on other sites More sharing options...
attaboybob Posted September 12, 2009 Share Posted September 12, 2009 I have an auto in my XJ and and AX-15 in my Comanche. both are for wheeling and DD the only time I would prefer auto is in traffic...period. BOB Link to comment Share on other sites More sharing options...
kar120c Posted September 12, 2009 Share Posted September 12, 2009 I'd take a manual transmission over an automatic anyday regardless of the vehicle. I also look at it this way: I do my own maintenance and spend extra money for high quality synthetic oil for my driveline. Manual transmission = ~ 2 qts Auto transmission = ~ 8 qts :D Link to comment Share on other sites More sharing options...
500 MJ Posted September 12, 2009 Share Posted September 12, 2009 Stick in the 4wd MJ and SOON TO BE stick in the 2wd MJ. I just need someone (GEONOVAST) to get back up to Wisconsin and swap his 2wd AX-15 out of his so I can swap it back in mine... :popcorn: P.S. I Really Really Really don't want to be swapping this thing over in the dead of winter... :rotfl2: Link to comment Share on other sites More sharing options...
