sinkrun Posted September 3, 2009 Share Posted September 3, 2009 My dealer can't quite deal with the fact that the o rings for the older 4.0 motor uses different o rings. Can some one confirm this and is there anyway to switch to the adapter from the newer motors and if so what years. I tried searching and came up with alot of hits but no answers. Link to comment Share on other sites More sharing options...
jpdocdave Posted September 3, 2009 Share Posted September 3, 2009 i wanna know to if i can swap adapters to use the more common filter. i keep thinking about it but never took anytime to figure it out. Link to comment Share on other sites More sharing options...
sinkrun Posted September 3, 2009 Author Share Posted September 3, 2009 Surely some one on here can tell us after its been posted for a while. Link to comment Share on other sites More sharing options...
ren Posted September 3, 2009 Share Posted September 3, 2009 Well, you can do it 2 ways. 1) Go to a partshouse and orde/ask for the Help brand kit, 82560. It is an "O"ring pack that services GM, Jeep, and Chrysler. 2) Go to the Dealership parts counter and sk for pt# 53007563AB. It is the threaded "insert" to change to the late oil filter. And Yes, you can swap to the late adpater, if you want to. Link to comment Share on other sites More sharing options...
Wildman Posted September 4, 2009 Share Posted September 4, 2009 Or.......you can use the part numbers from this link to tell your dealer what O-rings you need - http://www.lunghd.com/Tech_Articles/Eng ... -Rings.htm The problem with the "help" kit, there are 10 O-rings you don't need, and the large one you do need is not in the kit.........found this out the 'hard' way :roll: Link to comment Share on other sites More sharing options...
PIKE Posted September 4, 2009 Share Posted September 4, 2009 I think this is what you are looking for. http://www.jpmagazine.com/howto/5421/index.html Link to comment Share on other sites More sharing options...
HellBent Posted September 4, 2009 Share Posted September 4, 2009 on the earlier 4.0's, like my renix(just did the o-rings), the part numbers are three separate o-rings: 33002970, 33002971, and 33002972. one of each. Link to comment Share on other sites More sharing options...
BlueXJ Posted September 4, 2009 Share Posted September 4, 2009 Read MadXJ's write up on oil filter conversions. http://www.madxj.com/ Close to the bottom of the technical page under engine. Link to comment Share on other sites More sharing options...
sinkrun Posted September 4, 2009 Author Share Posted September 4, 2009 Many thanks guys rings are ordered from dealer along with the insert to switch to the newer filter style. I am going to turn my housing 90 deg`s will let you know how this all goes. Link to comment Share on other sites More sharing options...
