So i just installed the sye on the np231, all went well I have a 6" lift.... but now I'm into the driveshaft problem...its a 92 xj with again 6" lift and an 8.8 rear... I've heard that I can reuse a front driveshaft from a xj/mj and have it lengthened... any problems with that...? or any other ideas out there....thanks y'all......
couldn't you get a u joint that adapts to that flange and then bolt it on? just like a 1310 to a 1330 u joint. i've never done it, good point.
You need to get the spicer yoke (spicer part number 1379) for the flange to adapt a standard u-joint.
At 6" of lift in your XJ, you'll need to have a XJ 4.0L AW4 equipped front driveshaft lengthened. The front XJ shaft really only works with lifts upto 4".
You can try to find a 2WD Xploder in the wrecking yard. That's what I go the flange off of. The U-joint is a 1310, and the drive shaft needed to be shortened about 2", the slipyoke swapped for a Jeep/GM, and then it went right into place on my MJ. I kept the flange from the D/S to 8.8", in case I ever needed it or found a person that wanted to swap in an 8.8". I say this because I will not use that overpriced, piepan thick diff covered, leaky spline mother. ever. Even in my V8 Ranger or BroncoII.
:agree: The stock front is to short for anything over 4". My XJ lift settled in at just over 5 inches in the rear, I used a 97-98 ZJ front from a 4.0L. Auto.
89-00 XJ 4.0 Auto-30.66"
97-98 ZJ 4.0 Auto-33.00"
96-97 ZJ 4.0 Auto-31.25"
If you go with an XJ front style driveshaft with the double cardan joint at the transfer case end, you will have to rotate the axle quite a bit. That type of drive shaft is designed to run with a 0 degree joint angle at the axle end.
Rotating your rear axle that far would require a fill plug much higher up the diff cover than standard to be able to fill it to the correct level.
You may be better off getting a shaft with a single joint on each end.
