Darren Posted August 29, 2006 Posted August 29, 2006 First time poster, Just got my second Comanche had to drive from SW Washington to San Jose to get it. But anyway here's my problem for today. I have no power to anything in accesory and my crappy @$$ dome lights don't work. Any Ideas? I can't figure it out.
Hot Rod Jeep Posted August 29, 2006 Posted August 29, 2006 Don't know about the accesory, but I think it's just an MJ thing for the dome lights to not work. I've owned 2 and neither one had working dome lights. Sorry I wasn't more help. 8)
feerocknok Posted August 29, 2006 Posted August 29, 2006 What have you checked so far? Fuses alright? :dunno:
c0mt3k Posted August 29, 2006 Posted August 29, 2006 i'm not much help, i jsut wanted to gloat that my domelights work ^_^ well one of them, the other got ripped out :(
Pete M Posted August 29, 2006 Posted August 29, 2006 Even when they do work, they're still crappy. Many of us have added a dome light of some kind in the middle of the cab. :D
Kenosha Warrior Posted August 29, 2006 Posted August 29, 2006 know those push-in lights for your house that you tape to the wall? I glued one of them to the headliner in my MJ.
87manche Posted August 29, 2006 Posted August 29, 2006 back on topic: check the fuses, but also check the fuse block itself for distortion and the like. I see that your jeeps a 5spd, and the master likes to leak onto the fuse block. After that I'd check the ignition switch for the accesory problems. if the ignition switch is getting power and not passing it on then I suspect it, if it's not getting power check the fusible links under the hood.
Darren Posted August 30, 2006 Author Posted August 30, 2006 thanks for the advice, i'll check the ignition. yeah the fuse box is good that is what i checked first. and i'll work on a doing a led light swap. we'll see how it goes.
