'88 MJ Restification:
It's been a long time since I started this project, and it's been shelved several times over the years due to life and health issues. I'm now officially retired. Hopefully my enthusiasm and knees will hold up long enough to get this old girl back on the road again. I'm going to spend the next 4-6 weeks stockpiling parts to replace stuff that either just didn't work out or just needs to be upgraded. I'll post pics as stuff comes in and work as it's done.
  • Replies 586
I’ve been hoping for an update like that! Looking forward to updates again. :beerchug:
My original suspension set up was a RE 3.5 lift with fixed control arms. Later on, I added a spacer to the springs to level it out.
With the fixed arms the wheel was no longer centered in the wheel well and the caster angle was all wonked up. The first piece for the ol' parts pile arrived yesterday. A 37 pound box of happiness from Core4x4. Big beefy pieces (some assembly required).
54 minutes ago, neohic said:
Again, very excited to see an update! I’ve been following this thread since the first post. Welcome back!
 I appreciate it.
I picked up an open box HPS Short Ram Air intake (27-301WB) off eBay and installed it today. Hard to stay inside when it's 79 degrees.
I've got the Core arms and track bar. It seems like pretty solid stuff. I had 4" of lift on short arms and the ride was terrible.  I added RRO drop brackets and the difference was amazing, (currently has a probably sagged 5.5" lift). I know that everyone runs long arms now, but mine is pretty dialed in and dependable and I don't have any plans on changing things anytime soon. Glad to see that you're back on the build, congrats on the retirement!
I considered a long arm kit, but I'm going the route you did. I'm going to use 12° North Industries MJ kit. Thanks for the congrats.
Today's addition to the parts pile. Metalcloak 4.5 springs. Top notch folks. Called me the day after I ordered them to thank me and let me know they were on the way. Plus some Prothane insulators
Pretty sure those are identical to the Rocky Road Outfitters brackets that I bought. Same exact part number in fact. I liked the extra reinforcement in the back and the fact that it could act as a ramp if I was backing into an obstacle.
I'm sure you're right, both sites even use the same pics.
More parts. Russell brake lines including the ones for the rear calipers.
Also got my first box from CavFab, Track bar bracket and mount.
  • JeffK changed the title to '88 MJ Restification:
I'm still waiting on a few more parts to come in. I did finish painting what has come in. Final box from CavFab showed up with my track bar. Very impressive part.
5 hours ago, MiNi Beast said:
Dose that have a frame mount as well for the trac bar?
yeah, and a cross brace for the mount
Got my new tires mounted today, saved almost $60 a tire buying them from Tire Rack vs locally. I think they look pretty good on the JL wheels.
Compared to the worn 33s on my TJ.
On 4/5/2025 at 7:15 PM, JeffK said:
The CAD brackets came in from RRO today. The parts pile is nearing completion.
Those drop brackets are nice, I really like mine. Be prepared to do a fair amount of very small grinding in the frame's LCA pockets to get the fitment just so. The bracket kit was welded together with a MUCH higher degree of precision than your MJ was :roflmao:
Also, you'll find when setting the wheelbase with the Core 4x4 arms and the RRO brackets it'll want a very close to stock LCA length, with the arms adjusted just about to their shortest length, with the brackets set to dead center adjustment. That's what I found to be the case on mine, with about 6.75" lift up front on OME 2934 coils and ACOS.
