bought another, need front lift advice
  • Replies 54
Well, went down to Calgary today with the full intentions of driving this unit back here. Got there, and he had the jeep ready, inspection papers if I wanted to see them, etc. I told him far as I was concerned, I just wanted to jack the rear end, turn the wheel(s) and check the gear ratio - if it worked for me, I was slamming in a battery and driving away - especially seeing as it was the elusive 2.5l 4 cylinder automatic with the tow package, and more than likely the 4.56 gears and possible a dana 44, all for a grand total of $200...... :mrgreen:
That's when I walked around the rear end to check and make sure it had the hitch and saw this:
:shock: :shock: :shock:
There was a little bit of poetic inspiration that went through my head at that moment..... :cry: :cry: :cry:
The guy got "4 cylinder" and "4 litre" mixed up.
Well, thats not all bad.
Did it at least have the 44?
Even if it were a D35, and it ran well and everything .... $200 is still a killer bargain.
No 44, and $200 is a killer bargain, but I don't need it. I need axles with better gears than 3.07 for the manche.
Isnt this truck for your daughter,is she planning to use it a wheeler?
that XJ should have had 3.55 or 3.73 gears which should be fine with 32" or 33" tires if she doesnt want a dedicated trail rig.
