looking for a cam that lopes?
Is there a cam to put in my jeep that will have a slight lope?? Ive looked at all the comp cams and they say smooth idle. That’s all good, but I wish I could hear a jeep with a little lope. Not too much just a tad! Do yall know any body that makes one or have a video of one??
With a lopey idle, at some point, you're gonna P-off the computer.
If you don't go overboard, you can tighten up the lobe centers of a cam (as in 108, or 106 vs 110-112).
This increases the overlap, increasing the lope of the cam, while actually beefing up the bottom, to midrange.
It beefs up this range, because the total valve timing now happens over a shorter span.
This may be counter-intuitive, but tigher lobe centers really does = rougher cam, AND beefier bottom-midrange.
http://www.classicinlines.com/lobe_center.asp
Only problem is finding how out far the computer will let you go with this.
