Boilermaker Posted April 5, 2009 Share Posted April 5, 2009 General Information Trim LevelsBed Information MaintenanceEngine Identification, Specifications, Capacities and MaintenanceRead Engine Codes (Flashing check Engine Light)Torque Specs DrivetrainWhat Rear Axle do I have?What Gear Ratio do I have?How big a tire can I run on my axles?Which Manual Transmission Do I have?What does the Power/Comfort Switch on the dash do? SwapologyWhat wheels will fit my Stock MJWhat parts are MJ specific?What parts from a Cherokee can I use on my MJ? http://comancheclub.com/forums/viewtopic.php?f=2&t=17351http://comancheclub.com/forums/viewtopic.php?f=2&t=35480 What parts from other vehicles can I use on my MJ? http://comancheclub.com/forums/viewtopic.php?f=2&t=29868 What parts from other vehicles look like they would work but ARE NOT a direct swap Dakota tail lights ARE NOT a direct swap for MJ tail lightsXJ fuel senders are a mirror image of MJ fuel senders How Do I... Drivetrain Go from 2 Wheel drive to 4 Wheel DriveSwap out the BA 10/5 for a AX15 or AW4Add Power steering (2.5L '87) ElectricalFull Gauge Cluster Swap: [86-90] [91-92]Add Power Windows and Door LocksAdd (factory) Fog LightsReplace Cargo Area Lights InteriorAdd a Full Center ConsoleRemove the Dash/Off-site WriteupRemove the Interior TrimRemove the Bed Deal with Floorboard RustFinding LeaksReplacing with patch panelsMinor Surface Rust Service the BrakesGeneral Brake Procedures (off-site link to lunghd.com)Brakes for Dummies (offsite link to familycar.com)Bleeding the Brake System (starts with post 15)Brake Line AdjustmentsRear proportioning Valve 97+ XJ conversion Specific Information Front End Conversion on an '86 MJFront End Conversion ('87+ MJ) (under construction)DashSeatsDoorsWindshield Washer Fluid tank installation97+ Door handles and Mirrors on pre-97 doors Engine/Starting/Stalling Issues General Crank Position Sensor (CPS) problems Common Upgrades Dual Diaphragm Booster UpgradeV8 ZJ Swaybar SwapZJ Steering BoxMaking XJ Seat Brackets Work in an MJ97+ XJ Door SealsUnder Hood LightElectric Fan ConversionDisk Brake Conversion Under Construction....Please PM me or post other common questions (and ideally a link to a thread that answers them) Link to comment Share on other sites More sharing options...
cmelo Posted April 5, 2009 Share Posted April 5, 2009 Awesome, thankyou and I hope people build upon this. Link to comment Share on other sites More sharing options...
Darren Posted April 6, 2009 Share Posted April 6, 2009 nice. I like it. Link to comment Share on other sites More sharing options...
ren Posted April 13, 2009 Share Posted April 13, 2009 I have some info for the late model nose swap: The harness for the at least 88 model only needed the 3 wires for the front marker/turn signals spliced in. You do have to dig into the late style harness a little ways until you find the wiring "junction" from the factory, and then cut it BELOW the soldered splice. Now jsut splice it into your original harness, after you verify the correct wiring connection BEFORE you crimp/solder. Oh, and don't forget to cap off the extra "hot" wire on each side that you will end up with. Look at the "pass.side" pic, and you can see what I mean. Other than this, it was pretty much a "bolt on" over a couple of hours. :thumbsup: Link to comment Share on other sites More sharing options...
akamcbird Posted October 25, 2009 Share Posted October 25, 2009 lift springs jy style '83-'86 murc cugar coils v6=2" v8=3-4" so ive read.... Link to comment Share on other sites More sharing options...
jamespwsullivan Posted June 19, 2012 Share Posted June 19, 2012 If you're still around, what happened to the link below? What parts from a Cherokee can I use on my MJ? no hyperlink to anything. thanks Link to comment Share on other sites More sharing options...
