codybutz Posted April 2, 2009 Share Posted April 2, 2009 i've been looking around for a matching pair of d 44 for my 87 manche' and i came across these....i was just wondering what you all thought of them. or if there is somthing better that i should be looking for or pretty much any info that might help in my search. thanx 1990 jeep grand wagoneer parts front dana 44 60" wide 6x5.5 pattern driver side drop 3.31 gears $300 obo rear dana 44 60" wide 6x5.5 pattern center diff 3.31 gears $100 obo Link to comment Share on other sites More sharing options...
Darren Posted April 2, 2009 Share Posted April 2, 2009 offer him $300 for both. the 44 front is low-pinion, but better than a 30. Link to comment Share on other sites More sharing options...
codybutz Posted April 2, 2009 Author Share Posted April 2, 2009 At first i wasnt sure if i would want full width or not. thats not to big of a deal i guess...but the part of my build that i can not bring myself to do is to take the time to weld new spring perches on my d35, i mean at that point i might as well up grade the rear, right? Link to comment Share on other sites More sharing options...
Darren Posted April 2, 2009 Share Posted April 2, 2009 yes, do not spend a dime or any time on a 35. Link to comment Share on other sites More sharing options...
codybutz Posted April 2, 2009 Author Share Posted April 2, 2009 I have a lifted xj and i'm pretty good with a welder and torch but these would be my first axles swaps you think that these would be good to use for my Mj, right now i have the d30 vac disco. front and d35 rear. i'm guessing these would be great improvement Link to comment Share on other sites More sharing options...
Pete M Posted April 3, 2009 Share Posted April 3, 2009 I'd only buy the front 44. Then I'd go buy a rear 44 from a ~95ish 6cyl Isuzu Rodeo/Honda Passport. It's a Dana 44 with the same width and bolt pattern as the Waggy, but with disk brakes and a 4.10 or 4.30 ratio already installed. :thumbsup: The only catch is you'll want to install a U-joint flange on it instead of the flat flange. Link to comment Share on other sites More sharing options...
Geonovast Posted April 3, 2009 Share Posted April 3, 2009 I'd only buy the front 44. Then I'd go buy a rear 44 from a ~95ish 6cyl Isuzu Rodeo/Honda Passport. It's a Dana 44 with the same width and bolt pattern as the Waggy, but with disk brakes and a 4.10 or 4.30 ratio already installed. :thumbsup: The only catch is you'll want to install a U-joint flange on it instead of the flat flange. Then he'd have to regear the front. Link to comment Share on other sites More sharing options...
Pete M Posted April 3, 2009 Share Posted April 3, 2009 Yup. But he'd be doing that twice anyways. Who the heck wants 3.31 gearing? :dunno: Link to comment Share on other sites More sharing options...
Geonovast Posted April 3, 2009 Share Posted April 3, 2009 Yup. But he'd be doing that twice anyways. Who the heck wants 3.31 gearing? :dunno: Someone pushing 600 HP in a drag car. :brows: Link to comment Share on other sites More sharing options...
dakineJ Posted April 3, 2009 Share Posted April 3, 2009 I'd only buy the front 44. Then I'd go buy a rear 44 from a ~95ish 6cyl Isuzu Rodeo/Honda Passport. It's a Dana 44 with the same width and bolt pattern as the Waggy, but with disk brakes and a 4.10 or 4.30 ratio already installed. :thumbsup: The only catch is you'll want to install a U-joint flange on it instead of the flat flange. What is the width of this axle,and the MJ's? Is it sprung under? Link to comment Share on other sites More sharing options...
Pete M Posted April 3, 2009 Share Posted April 3, 2009 I forget the width, hopefully someone else has that on hand. As to the spring under/over, it doesn't matter. You'll be burning on new perches with any axle swap. :thumbsup: Link to comment Share on other sites More sharing options...
Rockyrider367 Posted April 3, 2009 Share Posted April 3, 2009 the issuzu rear is also disk brake and allot of them came with a possi :brows: I was thinking about it for mine untill I got a 9" Link to comment Share on other sites More sharing options...
