mopwrd340 Posted March 23, 2009 Posted March 23, 2009 here's the pictures i was suppost to put on here a while back ago. my great daughter did it for me. photobucket.com/mopwrd340 (copy and paste this link to view photos.) :yes:
Geonovast Posted March 23, 2009 Posted March 23, 2009 I love the grill... you should leave it that way! Gives it some teeth. :brows:
Wildman Posted March 23, 2009 Posted March 23, 2009 At first........I thought the grill was on up side down :hmm: But it's not. Easy fix, front clips are the same from an XJ donor :D And time to up grade to Chrome.
Geonovast Posted March 23, 2009 Posted March 23, 2009 I ran with upsidedown grills on both my XJs. Just flipped right over until they changed it in 91. I think it looked better that way. 8)
mopwrd340 Posted March 24, 2009 Author Posted March 24, 2009 hopefully i can start getting parts for it next month i pulled the front off today the frame horn was pushed in about 4 inches i can pull it back out bad thing is ruined to what looks like a new rad pushed it up about 1or2 inches also while looking around this thing still has the orignal plug wires on it with amc stamped on them i figured it say mopar on them
mvusse Posted March 24, 2009 Posted March 24, 2009 It doesn't say High Output under the 4.0 Litre, so it's an 87 through 90, which is the Renix (AMC) 4.0, so it would have AMC wires. Even though Chrysler already owned AMC (and thus Jeep by then), they didn't change to the High Output Chrysler version until 1991. Not much changed internally, but the engine control system is different, as is the intake manifold and cylinder head to allow for better airflow.Less low end torque, more higher end torque and thus HP. The debate is still on about which engine is better in a truck.
