Weezel Posted July 30, 2006 Share Posted July 30, 2006 I have a 91 mj 2wd going to be 4wd in a week or so.... here is the question, when i swap in the front axle i want to put the lift in while i am at it. i have an opportunity for a set of RE 4.5" coils... the price is right but is it too much lift. it is going to be my daily driver and i am running factory tj rubicon wheels and tires (about 31's) i think it will be too much. the mj is quite low in the front right now, will that change with just the axle swap? or are the 2wd coils that much smaller? Thanks in advance W :Canadaflag: Link to comment Share on other sites More sharing options...
Bounty Hunter Posted July 30, 2006 Share Posted July 30, 2006 I think it'd be just right for those tires, go for it. Link to comment Share on other sites More sharing options...
BIGHEEP Posted July 30, 2006 Share Posted July 30, 2006 I think it'd be just right for those tires, go for it. I agree..... Go for it. Link to comment Share on other sites More sharing options...
Weezel Posted July 30, 2006 Author Share Posted July 30, 2006 does anyone have any pics of a similar set-up.... also any info on the 2wd coils and the stock 4wd coils? i am curious if the 2wd coil are alot shorter. my MJ looks like a low rider right now!! thanks for the quick responses W :Canadaflag: Link to comment Share on other sites More sharing options...
BIGHEEP Posted July 30, 2006 Share Posted July 30, 2006 does anyone have any pics of a similar set-up.... About like that. also any info on the 2wd coils and the stock 4wd coils? i am curious if the 2wd coil are alot shorter.my MJ looks like a low rider right now!! thanks for the quick responses W :Canadaflag: The coils are the same. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted July 30, 2006 Share Posted July 30, 2006 Here si a shot of my MJ before 33"s...its almost 7" of lift up front and five in the rear on 31" BFG at's Sorry for the rain pics...cannot find my good pics... CW Link to comment Share on other sites More sharing options...
Weezel Posted July 31, 2006 Author Share Posted July 31, 2006 thanks everyone.... i took a couple of pics of my "low rider MJ" but i can't post them... go figure. i did however measure from the garage floor to the lip of my fender flare and it measured 30 1/2"in the front and 33 3/8" in the rear. does this sound right for a stocker? also it has 235/75/15's on it. what should a 4 1/2" lift measure sitting on 31's from ground to flare? thanks again for the input W :Canadaflag: Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 31, 2006 Share Posted July 31, 2006 If you want a measurement that does not depend on the height of the tire, measure from the hub centre to the bottom of the fender flare. Link to comment Share on other sites More sharing options...
Pete M Posted July 31, 2006 Share Posted July 31, 2006 2wd MJs are 1" shorter than 4wd MJs. Link to comment Share on other sites More sharing options...
