clarkerussell Posted July 25, 2006 Share Posted July 25, 2006 First off, why would someone want an internal slave cylinder? Secondly, was the AX15 made with either an internal or external slave cylinder? If both, what years were external? Lastly, is the NV3550 an internal or external slave design? Thanks in advance. Clarke Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 25, 2006 Share Posted July 25, 2006 The only reason for wanting an internal slave is that the slave can't as easily be damaged by outside factors. However, you've got to pull the tranny to change the slave... The external slaves are desireable because of this. AX-15 were either. Think the change was in 96. Maybe 94. NV3550's are external, IIRC. Link to comment Share on other sites More sharing options...
clarkerussell Posted July 25, 2006 Author Share Posted July 25, 2006 Cool. I'll proceed forward with the NV3550... Link to comment Share on other sites More sharing options...
Oizarod115 Posted July 26, 2006 Share Posted July 26, 2006 ax15s after 94 are external Link to comment Share on other sites More sharing options...
sinnaevd Posted July 26, 2006 Share Posted July 26, 2006 wait wait wait, IIRC means If I Remember Correctly? Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 26, 2006 Share Posted July 26, 2006 wait wait wait, IIRC means If I Remember Correctly? Yeah. Link to comment Share on other sites More sharing options...
sinnaevd Posted July 26, 2006 Share Posted July 26, 2006 my MJ is an 89, 4.0 spd. was the tranny change over in 89? did i get stuck with the goat? it doesn't really matter as i'm switching over to the aw4 n e way, but curious Link to comment Share on other sites More sharing options...
87manche Posted July 26, 2006 Share Posted July 26, 2006 the changover was mid year 89. Take a look at the trans itself, if it splits from front to rear it's the goat, if it splits into 3 sections through it's cross section it's an AX-15. Is there anything wrong with your 5 sp? If it's an AX-15 I would be willing to drive and get that. Junk yards around here want $400 for a used trans. Link to comment Share on other sites More sharing options...
sinnaevd Posted July 26, 2006 Share Posted July 26, 2006 i don't thikn the clutch is very good but it seems to go in and out of gear fine. once i get it out, (probably won't be for a while), i will let you have it. if you get one befor then, someone on here can be the lucky sole. Link to comment Share on other sites More sharing options...
Oizarod115 Posted July 27, 2006 Share Posted July 27, 2006 it depends on if your truck is an 89 MODEL or was BUILT in 89. cause alot of 89s wouldve been built in 88 correct? my 89 definately has the pukegoat. Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 27, 2006 Share Posted July 27, 2006 it depends on if your truck is an 89 MODEL or was BUILT in 89. cause alot of 89s wouldve been built in 88 correct? my 89 definately has the pukegoat. I don't think so. I think that practice was only really brought in in later years. My 89 was built in 89, has a BA10/5. I forget the exact date. It's not like it matters, it's got parts from so many different vehicles on it. Link to comment Share on other sites More sharing options...
ROADLESS Posted July 28, 2006 Share Posted July 28, 2006 it depends on if your truck is an 89 MODEL or was BUILT in 89. cause alot of 89s wouldve been built in 88 correct? my 89 definately has the pukegoat. My 89 has the AX15 and was made in March of that year :chillin: Link to comment Share on other sites More sharing options...
Oizarod115 Posted July 29, 2006 Share Posted July 29, 2006 it depends on if your truck is an 89 MODEL or was BUILT in 89. cause alot of 89s wouldve been built in 88 correct? my 89 definately has the pukegoat. My 89 has the AX15 and was made in March of that year :chillin: this is me being jealous :mad: haha Link to comment Share on other sites More sharing options...
pingpong Posted July 29, 2006 Share Posted July 29, 2006 I know everyone is sold on the NV3350, or the nv4500, but has anyone ever considered the NP435... I know it is only a 4spd, but they are cheap, easy to find, and just about indestructible.I know of one guy in the club I belong to is running it behind his 2.5, and he loves it. Just some food for thought Link to comment Share on other sites More sharing options...
Oizarod115 Posted July 30, 2006 Share Posted July 30, 2006 pingpong, you got any extra information on that tranny? it doesnt matter to me whether i have overdrive or not, as it is i never use 5th even at 60+ cause it makes scary noise. Link to comment Share on other sites More sharing options...
Pete M Posted July 31, 2006 Share Posted July 31, 2006 How does a 435 bolt to the 4.0L? Or am I thinking of the wrong trans... Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 31, 2006 Share Posted July 31, 2006 How does a 435 bolt to the 4.0L? Or am I thinking of the wrong trans... It doesn't without adapters. Link to comment Share on other sites More sharing options...
