Jsut finished putting the MJ back together after painting it and now it will not start. Made sure the ground for the taillights/fuelpump is grounded well. Checked the battery, it was toast, got a new one. Put new battery in and still will not start nor turn over. NO clicks or anything. I tried pulling the lights on, and they stay one when the key is turned, the after market radio however turns off when the key is turned to start. I am going to pull the starter today and have it tested today, if it does not snow too much before I get to it. Any ideas if the starter is good? :headpop:
I will try that first, a lot easier to get to as well and less expensive to change. I did not hear any sounds at all. Hopefully that is it.
check the fuseable link coming from the starter going into the cab. if it stretches, cut it off and run a wire to your battery with a fuse to the right amperage.
Auto or manual? I have an intermitent problem w/ the PRNDL switch not allowing truck to start. Put the truck in neutral and try to start it. Or just wiggle the shifter while trying to start. Good luck :thumbsup:
Well it is now alive once again. Turned the key on and jumped the starter solenoid and she fired up. Drove it to the shop to finish hanging the exhaust back up, pulled it in shut it down and it refired 3 times. Must have been froze up from the cold weather?
Well it let me down again, starting to think the ignition swith in the column may be bad or need adjusted. Anyone have specs on how to adjust it?
