project88mj Posted December 25, 2008 Share Posted December 25, 2008 it starts at the airtube next to the box goes along the fire wall here: then connects to a black canester that is under fill tank for the coolant: Link to comment Share on other sites More sharing options...
mvusse Posted December 26, 2008 Share Posted December 26, 2008 Without looking under my hood, but going by your description it would be the purge line from your charcoal cannister. That cannister traps gasoline vapors from your fuel tank. When the engine is running they get sucked in and used up. Link to comment Share on other sites More sharing options...
Pete M Posted December 26, 2008 Share Posted December 26, 2008 Yup, sounds about right to me. :thumbsup: Link to comment Share on other sites More sharing options...
BLHTAZ Posted December 26, 2008 Share Posted December 26, 2008 :agree: It is the vacuum line to the purge canister :thumbsup: Link to comment Share on other sites More sharing options...
project88mj Posted December 30, 2008 Author Share Posted December 30, 2008 do i need it or not? Link to comment Share on other sites More sharing options...
ocskipper Posted December 30, 2008 Share Posted December 30, 2008 Yes, it is part of your emmissions systems and the truck will not smog or run right without it... Link to comment Share on other sites More sharing options...
project88mj Posted December 30, 2008 Author Share Posted December 30, 2008 smog not sure how my truck smogs? Link to comment Share on other sites More sharing options...
project88mj Posted December 30, 2008 Author Share Posted December 30, 2008 That cannister traps gasoline vapors from your fuel tank. When the engine is running they get sucked in and used up. so do i NEED it for my truck too run fine? here in oklahoma we don't have too pass emmitions tests or inspections Link to comment Share on other sites More sharing options...
ocskipper Posted December 30, 2008 Share Posted December 30, 2008 Yes, you need it for your truck to run correctly. There is no need to remove it, what is your motive? Link to comment Share on other sites More sharing options...
project88mj Posted December 30, 2008 Author Share Posted December 30, 2008 i want to run a cone filter Link to comment Share on other sites More sharing options...
Randy in Maine Posted December 30, 2008 Share Posted December 30, 2008 Keep what you have. These things have lots of issues but "getting more air via a cone filter" is not one of them. Link to comment Share on other sites More sharing options...
BLHTAZ Posted December 31, 2008 Share Posted December 31, 2008 There are cold air intake set-ups that will allow you to keep all the needed hoses in place. A little ingenuity and you can make one yourself using most of your existing parts ;) Link to comment Share on other sites More sharing options...
Pete M Posted December 31, 2008 Share Posted December 31, 2008 They are only "cold air" if they close off the intake from the rest of the engine bay. Otherwise they are more of a "hot air". Link to comment Share on other sites More sharing options...
bigd44889 Posted December 31, 2008 Share Posted December 31, 2008 what if u take the fuel tank off and run a fuel cell and plug the vacume from tank to canister oh i know still runs great u don't need it it is a fancy breater for the gas tank disciption above is how mine is set up and runs fine mine will soon be cold air cone filter thu the hood Link to comment Share on other sites More sharing options...
Pete M Posted December 31, 2008 Share Posted December 31, 2008 If you have no need for the charcoal canister, then you can simply cut it off from the system. But regular gas tanks like to leak vapors and those vapors need a place to go rather than just stinking up your truck. Link to comment Share on other sites More sharing options...
ocskipper Posted December 31, 2008 Share Posted December 31, 2008 The smell is the problem I had when mine went bad. I couldnt fix it fast enough! :ack: If you take it off make sure you know what your doing. Link to comment Share on other sites More sharing options...
project88mj Posted December 31, 2008 Author Share Posted December 31, 2008 can't i just cap it at the tank and be done with it? if the vapors can't get to the charcoal canister they should not be an issue right? Link to comment Share on other sites More sharing options...
Pete M Posted December 31, 2008 Share Posted December 31, 2008 Pressure from inside the tank will push the vapors out through one way or the other. The canister and its tube give it a place to go, the charcoal absorbs the particles, and then the vapors are pulled into the engine due to vacuum from the engine. Link to comment Share on other sites More sharing options...
project88mj Posted January 1, 2009 Author Share Posted January 1, 2009 so i need to just get the gasses back into the motor right? Link to comment Share on other sites More sharing options...
jtdesigns Posted January 2, 2009 Share Posted January 2, 2009 so i need to just get the gasses back into the motor right? Yes,, but don't burn your truck to ground getting it there. You can run a cone, I'd just cut a slightly smaller hole then the hose in the intake tube and seal it with a lil RTV. You'll be OK, but don't remove it... Link to comment Share on other sites More sharing options...
project88mj Posted January 2, 2009 Author Share Posted January 2, 2009 sounds good to me :thumbsup: Link to comment Share on other sites More sharing options...
