mjeff87 Posted December 18, 2008 Posted December 18, 2008 Anyone running them? Do they fit MJ's? are they any good? I really need longarms...but they're running a special on DB's for $129.....thinking about a set to run until I get up the $$$ for LA's. TIA, Jeff
redneck23ms Posted December 18, 2008 Posted December 18, 2008 where did you see the $129 special? and how long is this deal going to last? the brackets will work on mj's but the braces won't. i asked about the braces a couple weeks ago and several on here assured me that the braces aren't needed on mj's since they have the welded on lca mount brace already.
mjeff87 Posted December 18, 2008 Author Posted December 18, 2008 go to the RC website...they're having "deal of the day" specials. The DB's are one of today's specials. http://www.roughcountry.com/deal_a_day.html I might just go ahead and buy myself a set for Christmas :yes: Jeff
pingpong Posted December 18, 2008 Posted December 18, 2008 I ran RE db's on Pong for a yr or so... they flex great. I am sure they are the same design. They are a bit of a PITA to install, but they are great. If you want once you install them and if you feel it is needed I think I can fab up som reinforcement brackets.
mjeff87 Posted December 19, 2008 Author Posted December 19, 2008 Thanks Pat. As usual, I'll bring the beer, and I still have that box of rods for you from when we did the perches. My wife just bought me a set of DB's for Christmas....but she doesn't know it yet :banana: $156 and change with shipping. Jeff
WahooSteeler Posted December 19, 2008 Posted December 19, 2008 Jeff, I could swear I've seen a tech thread either here or on jeepforum where someone made the support brackets work after a little grinding and other work. might be easier to fab some up with pong, but just an fyi................
redneck23ms Posted December 19, 2008 Posted December 19, 2008 just got my order in as well. now just gotta wait for brown santa to deliver them
shelbyluvv Posted December 19, 2008 Posted December 19, 2008 just got my order in as well. now just gotta wait for brown santa to deliver them Me Too!
pingpong Posted December 21, 2008 Posted December 21, 2008 Jeff, I could swear I've seen a tech thread either here or on jeepforum where someone made the support brackets work after a little grinding and other work. might be easier to fab some up with pong, but just an fyi................ I have some 4x4x1/4 angle and some 4"x 1/4 flat..... A lil cutting, welding and a lil work on the drill press... should be able to make a set of reinforcements after measureing in less then 20 minutes :smart: all ready have half a plan for it :D
mjeff87 Posted December 23, 2008 Author Posted December 23, 2008 mine are on schedule for delivery today, at the family house up in PA. I won't get to see them until tomorrow night :drool: Jeff
shelbyluvv Posted December 24, 2008 Posted December 24, 2008 Brown Santa dropped mine off today! :wavey:
redneck23ms Posted December 24, 2008 Posted December 24, 2008 just finished installing mine. install went pretty smoothly except for the lca bolts being extremely frozen up and my adjustable lca's were pretty well froze up too. after lost of beating and prying i finally got them loose. and applied lots of anti-sieze. and for the braces it appears that we may be able to cut one side of the frame end off and get it to fit. that will only leave one bolt hole on the frame side though. i'm going to work on that tomorrow and see how it turns out
Rokhound Posted December 24, 2008 Posted December 24, 2008 they work great only hung me up once but then again the rock also hung up a 44" TSL and I am on 34's here is the best pic i have of me being hung up And here is the video If you look at rocky road i think they have a set for the mjs with the supports thats they only thing that won't work.
redneck23ms Posted December 24, 2008 Posted December 24, 2008 i copy and pasted this to keep from another site i'm on having to type it all again got some control arm drop brackets for christmas installed them yesterday/today. the install on the brackets themselves was pretty easy. my adjustable arms gave me a bit of trouble due to them being froze up and the bolts also being froze up. finally got them all off and freed up before after
redneck23ms Posted December 24, 2008 Posted December 24, 2008 then it came time to install the braces. well these are designed for a xj and i have a mj. mj's have a big reinforcement welded onto the lca mount so the braces won't work in stock form. most guys simply don't worry with them and leave them off. i liked the idea of having them for strength and they also form a ramp to help keep from getting hung up on the brackets. so i cut half of the brace off where the reinforcement is and drilled a new hole for an additional bolt got it all bolted up and ready to go now
Rokhound Posted December 24, 2008 Posted December 24, 2008 ^^^Sweet I might have to try that.^^^ Here is what i would really like to have I like there brace http://www.rocky-road.com/xjcad.html I wouldn't think it would be hard to modify RC brackets to look like the Rocky Road's.
pilotblake Posted April 13, 2009 Posted April 13, 2009 If the original authors or anybody since this post was started reads this.....I am installing the rough country control arm drops. I am having trouble getting the side bracket that hold the UCA in place. The bolt holes do not line up even with the upper hole being oblong on the top side of the bracket. Also I have my control arms screwed in as far as they would go to keep the axel close to where it was before, is this normal. My truck actually has the same looking LCAs as the maroon truck in this thread, including ride height. Any other words or advice on this install would be great also.
mjeff87 Posted April 13, 2009 Author Posted April 13, 2009 Sadly, mine are still sitting in the box they came in :( They are #2 on the list to do, right behind pulling the head on my TJ once we get into our new garage, errr....house, in June (hopefully). From memory, though, those brackets seem to be specific to each side...did you try switching sides with them? Jeff
shelbyluvv Posted April 13, 2009 Posted April 13, 2009 I just finished doing mine about 20 mins ago. Everything went smooth as silk. Except putting the stock alignment shoes and LCAs back into the RC pockets. I had to beat, pry, bend, and cuss to get them in. Once I figured it out the other side went easy as pie. The UCA brackets are side specific. It can be confusing to get them right. It took me a few mines to get them on too.
pilotblake Posted April 13, 2009 Posted April 13, 2009 I would swear I have them right, but when I put the bracket on the bottom hole that is round I am off on the very top where it is oblong and bolts onto the UCA pocket. I also had to beat the lower control arm bracket into place since the old pocket was squished in alittle to the width of the control arm joint. I swear if it wasn't for bad luck I would have no luck at all. When I get home I will look at it again, I just hate to start tweaking the new stuff till I know what is the culprit.
redneck23ms Posted April 14, 2009 Posted April 14, 2009 mine bolted right up with no problem. be sure you don't pinch the speedo cable when tightening the drivers side upper bracket
dakal Posted April 14, 2009 Posted April 14, 2009 if you read rocky roads info, the pictures show normal and lifted. mine isn't normal and looks like the lifted one. but i don't have 6 in of lift. why do they say only on 6 in of lift or more? i like the idea of using them. rc are now $200.00 today. rr are now $195.00 today. :help:
pilotblake Posted April 14, 2009 Posted April 14, 2009 If I have adjustable upper and lower arms do i still need to put the shims and bracket deal in the lower control arm pocket(the deal with the two bolts that stick out the back of the pocket?) can't this adjustment be made on the arms themselves. Also I had to add a couple washers on the upper arms to fill the space between the new upper arm brackets.
shelbyluvv Posted April 14, 2009 Posted April 14, 2009 If I have adjustable upper and lower arms do i still need to put the shims and bracket deal in the lower control arm pocket(the deal with the two bolts that stick out the back of the pocket?) can't this adjustment be made on the arms themselves. Also I had to add a couple washers on the upper arms to fill the space between the new upper arm brackets. The alignment shoes have a hole in the center, while the brackets have a slit for them to adjust using shims. I would use the shoes to keep the arms from even having the chance to slide in the pockets.
