robfg67 Posted December 17, 2008 Share Posted December 17, 2008 I'm buying a NP 242 from our good friend Twisty and I have a few questions not answered in any of the multiple forum searches. My MJ is an '89 with the 4.0L and 5-speed BA-10 transmission with the CAD on the front axle. 1. I plan on shimming the CAD so it is always engaged. Does the other end of the vacuum wires at the TC get used? If not, can I just take them out altogether? 2. Will the 231 vent hose fit on the 242? 3. Will my speedometer cable fit on the 242? 4. Can I reuse the shift fork linkage from my 231 on the 242? Thanks fellas, and Twisty, feel free to chime in too! Link to comment Share on other sites More sharing options...
DirtyComanche Posted December 17, 2008 Share Posted December 17, 2008 Should be good one 2 and 3. And I think 4 as well, it just needs to be adjusted. For #1 you can rip all the lines out, buy you'll lose the 4wd indicator light. No biggy? Link to comment Share on other sites More sharing options...
Pete M Posted December 17, 2008 Share Posted December 17, 2008 My first question is; what's the spline count on that 242? Link to comment Share on other sites More sharing options...
mjeff87 Posted December 17, 2008 Share Posted December 17, 2008 I'm buying a NP 242 from our good friend Twisty and I have a few questions not answered in any of the multiple forum searches. My MJ is an '89 with the 4.0L and 5-speed BA-10 transmission with the CAD on the front axle. 1. I plan on shimming the CAD so it is always engaged. Does the other end of the vacuum wires at the TC get used? If not, can I just take them out altogether? only if you want the 4WD indicator light on the dash to work, if not, cap off the switch on the TC (I just wrapped mine in duct tape :D) 2. Will the 231 vent hose fit on the 242? yes 3. Will my speedometer cable fit on the 242?yes 4. Can I reuse the shift fork linkage from my 231 on the 242?yes, but you may want to switch the bezels to show the 4H full time position Thanks fellas, and Twisty, feel free to chime in too! Link to comment Share on other sites More sharing options...
robfg67 Posted December 17, 2008 Author Share Posted December 17, 2008 The doner is out of a 1990 XJ, 21 spline input. I found one post on a Cherokee Forum site that said mine is also a 21 spline. What do you say Pete? Link to comment Share on other sites More sharing options...
DirtyComanche Posted December 17, 2008 Share Posted December 17, 2008 I don't think so. Early AW4s were 21 spline. But that ended in 89 with the introduction of the AX-15 (23 spline), AFAIK. But, they might well have still used a 21 spliner in a 90. Edit, althought it might have been behind a TF-904 I guess. I think they're 21 spline. Link to comment Share on other sites More sharing options...
robfg67 Posted December 17, 2008 Author Share Posted December 17, 2008 I have the 5-Speed Peugeot (BA-10) in my '89. Link to comment Share on other sites More sharing options...
DirtyComanche Posted December 17, 2008 Share Posted December 17, 2008 Oh, your BA10-5 is 21 spline. I thought you hadn't counted the splines on the tcase input yet. Link to comment Share on other sites More sharing options...
