BLHTAZ Posted December 11, 2008 Posted December 11, 2008 You need to reduce it to the proper size to fit in that spot. I think it is limited to about 80 - 100 pixels wide for an avatar. EDIT: Here...try this. Save it to your file and then try to load it. Image Not Found
GaruMJ Posted December 11, 2008 Author Posted December 11, 2008 thanks! but doesn´t work how could I reduce it?
GaruMJ Posted December 11, 2008 Author Posted December 11, 2008 thanks! but doesn´t work how could I reduce it? I used paint to reduce it. thanks!!!!!!!!!!!!!!!!! :clapping: :clapping: :clapping:
Pete M Posted December 11, 2008 Posted December 11, 2008 there's always plan B: I'll do it for ya. :thumbsup: Keep learning though. Some day the knowledge will come in handy. :cheers: To reduce I use a program called ACDSee. Does a good job of retaining details as it gets shrunk. I can even just type in 100x150 and it'll shrink tit to those specs. Last time I used Paint for that it was a real pain in the butt. :(
GaruMJ Posted December 11, 2008 Author Posted December 11, 2008 Last time I used Paint for that it was a real pain in the butt. :( It was :wall: , thanks anyway :thumbsup:
BLHTAZ Posted December 11, 2008 Posted December 11, 2008 thanks! but doesn´t work how could I reduce it?There is no reason that the one I did would not work...it's just a reduced piture, but I'm glad you got it figured out anyway. :thumbsup:
89eliminator Posted December 11, 2008 Posted December 11, 2008 and it'll shrink tit now why would you want to do that? :banana:
jtdesigns Posted December 11, 2008 Posted December 11, 2008 and it'll shrink tit now why would you want to do that? :banana: its fine as long as the @$$ expands !!! :rotfl2:
mvusse Posted December 12, 2008 Posted December 12, 2008 and it'll shrink tit now why would you want to do that? :banana: Because any more than a handful is a waste. :D
