comanche13 Posted December 10, 2008 Share Posted December 10, 2008 these guys make a sye that is shorter then a normal one what is the advantage? http://www.jbconversions.com/pages/ Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 10, 2008 Share Posted December 10, 2008 it allows for a longer driveshaft, which increases the distance between the axle pinion and the t-case, meaning a longer driveshaft and a less extreme driveshaft angle (less chance of vibes, less worn u-joints) Link to comment Share on other sites More sharing options...
BLHTAZ Posted December 10, 2008 Share Posted December 10, 2008 these guys make a sye that is shorter then a normal one what is the advantage? http://www.jbconversions.com/pages/ I put that one in our YJ about 2 years ago. Nice kit... :thumbsup: Link to comment Share on other sites More sharing options...
Pete M Posted December 10, 2008 Share Posted December 10, 2008 It's not especially necessary on an MJ (we have much longer rear driveshafts and so U-joint angles are less severe), but if you can float the money, it's a good upgrade. They tend to be stronger than stock and they seal up the back of the t-case so you can pull the driveshaft without spilling fluid all over the place. Link to comment Share on other sites More sharing options...
Motion Offroad Posted December 10, 2008 Share Posted December 10, 2008 The mega-short SYE's are made for the wrangler guys who are running large lifts. The d-shafts on the wranglers are VERY short and they need all the extra clearance that they can get. On the MJ's it's not recommended to go with the mega-short SYE. A normal one works fine and will work on the NP231 (j-version) on the MJ's better than the mega-short one's do. Link to comment Share on other sites More sharing options...
DirtyComanche Posted December 11, 2008 Share Posted December 11, 2008 As motion said... Go with a regular one... The benefits are none on a MJ. FWIW, PORC has their HD SYE on for $159.99 US (IIRC). Gotta mention the word 'pirate4x4' though. Link to comment Share on other sites More sharing options...
