manche Posted December 5, 2008 Share Posted December 5, 2008 if i was to buy this kit http://4wdtruck.com/jeepparts/index.php ... s_id=19583 would i need any steering components also >???? :huh???: :hmm: Link to comment Share on other sites More sharing options...
project88mj Posted December 5, 2008 Share Posted December 5, 2008 i know that 2" is okay with no steering mods but 3" I'm not sure :hmm: i know that if you go with 5+" you do need steering mods but I'm not sure what kind :dunno: Link to comment Share on other sites More sharing options...
manche Posted December 5, 2008 Author Share Posted December 5, 2008 will i need like track bar pitman arms and thing like that :hmm: btw is that a good deal on the lift you guys think :typing: Link to comment Share on other sites More sharing options...
project88mj Posted December 5, 2008 Share Posted December 5, 2008 my younger brother got a rough country lift for his FSJ and loves it track bar: I'm sure lower control arms: olny if you don't like how it rides upper control arms: nope pitman arm: nope Link to comment Share on other sites More sharing options...
BLHTAZ Posted December 5, 2008 Share Posted December 5, 2008 -In my opinion...you will definitely need to replace both the UCA's and the LCA's...especially if you are going to wheel it as the stock arms are weak junk. -You will need an adjustable track bar. -No pitman arm is needed. Just remember if you buy that kit...you get what you pay for. Cheap means cheap :smart: . It's a good price...BUT... Link to comment Share on other sites More sharing options...
Pete M Posted December 5, 2008 Share Posted December 5, 2008 You couldn't pay me to put a 3" lift sans LCAs on one of my MJs. The tire gets pulled back in the wheelwell with the stock arms. Link to comment Share on other sites More sharing options...
project88mj Posted December 5, 2008 Share Posted December 5, 2008 do you really need both uca and lca Link to comment Share on other sites More sharing options...
BLHTAZ Posted December 5, 2008 Share Posted December 5, 2008 project88mj said: do you really need both uca and lcaAs I said...IMO yes. Definitely need LCA's at minimum, but if the truck is going to be a wheeler...both are STRONGLY recommended ;) Link to comment Share on other sites More sharing options...
project88mj Posted December 5, 2008 Share Posted December 5, 2008 Pete M said: You couldn't pay me to put a 3" lift sans LCAs on one of my MJs. The tire gets pulled back in the wheelwell with the stock arms. what is sans? Link to comment Share on other sites More sharing options...
89eliminator Posted December 5, 2008 Share Posted December 5, 2008 project88mj said: Pete M said: You couldn't pay me to put a 3" lift sans LCAs on one of my MJs. The tire gets pulled back in the wheelwell with the stock arms. what is sans? he means he wouldnt put a 3in lift without new lca's. i also recommend new lca's but i don't think you need new uppers. i lengthened mine and they've held up for 3+ years of dd'ing and moderated to hard wheeling. Link to comment Share on other sites More sharing options...
project88mj Posted December 5, 2008 Share Posted December 5, 2008 see i would like to buy a set of springs that will give me 3"-4" of lift but i have no idea what to do :dunno: do i need to buy a kit like the op did. Or will stock springs from another type of jeep fit in there and give me some lift? :dunno: Link to comment Share on other sites More sharing options...
89eliminator Posted December 5, 2008 Share Posted December 5, 2008 your best would be to buy a kit. i don't know of any other truck springs that would give a lift. Link to comment Share on other sites More sharing options...
BLHTAZ Posted December 5, 2008 Share Posted December 5, 2008 project88mj said: see i would like to buy a set of springs that will give me 3"-4" of lift but i have no idea what to do :dunno: do i need to buy a kit like the op did. Or will stock springs from another type of jeep fit in there and give me some lift? :dunno: You could probably hack together a kit that would do what you want, but it would be just that...a hack job. The best, safest and smartest thing to do is spend the $700 - $900 on a good kit and have it done right with upper & lower LCA's, track bar & rear springs. 89eliminator said: i don't think you need new uppers. i lengthened mineHow on earth did you lengthen a stock control arm. They are nothing but weak pressed sheet metal and making them longer would just make them weaker. You must have done something to strengthen them as well as lengthen them or you would not be using them right now...especially if you have ever really wheeled them. ;) Link to comment Share on other sites More sharing options...
89eliminator Posted December 5, 2008 Share Posted December 5, 2008 i had another stock upper in which i took 2 pieces off. then cut each upper in half and welded in the piece. i did put another 1/2in piece of flat stock "inside" on each on too. Link to comment Share on other sites More sharing options...
manche Posted December 11, 2008 Author Share Posted December 11, 2008 that sounds dangerous :nuts: Link to comment Share on other sites More sharing options...
