i do beleive that the D50 was in the same realm as the chevy LUV & ford courier and a by product of mitsubishi i could be wrong but that is what i remeber. You would have to check the measurements. I would recommend a ford or mopar product for axles
Yes the Ram 50 is a Mitsu pick up. The front is IFS, the rear is a third member set up, and fairly strong. Most of them came with 3.90 or 4.10 gears. 4x4 should have 6 lug wheels though.
You would need the ones out of a hi-pinion D30. And you would need the carrier.
And you'd be better off swapping the entire axle than swapping the gears. Unless you want to do a gear setup. Which I can assure you that you don't. And I'm not a fan of used gears anyways.
