I'm in the process of building up a HP Dana 30. While I'm doing it, I'm going to go ahead and upgrade the steering since it binds at full flex anyway. I'm looking pretty seriously at the Motion Offroad crossover system. Anyone running it? Any input?
I'm running the JCR 1 ton setup and i highly recomend it , its not a direct bolton but is very easy.
mine is setup OTK just so u know
The "motion offroad" setup is built by rugged ridge and can be found cheaper elseware. But i wouldnt run it anyway. My buddy just removed that same kit to go with v8 zj steering.
If I were you I would run the JCR kit unless you do a lot of driving on pavement then I would go with the Currie kit. JCR is beefier, the currie kit is not as stout but handles much better on the street. the currie setup is very nice.
Right now i have the ZJ upgrade but have a used Rock Krawler setup sitting in my garage...just too lazy to put it on but my buddy uses the RK kit on his MJ and loves it
