M2 CARBINE Posted November 13, 2008 Share Posted November 13, 2008 Well I just had it i can't figure out why my manche won't crank nothing works but the lights does anybody work on them in georgia willing to pay whatever thanks Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted November 13, 2008 Share Posted November 13, 2008 Your sig says it's an '86 with the 4.0L. The '86 never came with that option so I'm assuming that someone swapped it in at somepoint. Give us some more info on what you have as far as the motor/tranny combo goes. It the lights work and it won't even crank I'd check to see if you have power to the starter. If it's an auto (Aw4) it may be the NSS. Try putting the tranny in (N) and see if it turns over. Link to comment Share on other sites More sharing options...
M2 CARBINE Posted November 13, 2008 Author Share Posted November 13, 2008 I have a a topic in the build forum under 86 XLS i have changed the NSS 2 times and still nothing Link to comment Share on other sites More sharing options...
Pete M Posted November 13, 2008 Share Posted November 13, 2008 Does the starter relay click? What are the condition of the battery cables? Where in GA are you? Link to comment Share on other sites More sharing options...
M2 CARBINE Posted November 13, 2008 Author Share Posted November 13, 2008 It's not clicking just turn key nothing the fuel pump not even kicking on. I'm 15 min outside Atlanta Link to comment Share on other sites More sharing options...
BookspanS Posted November 13, 2008 Share Posted November 13, 2008 Check ALL the plugs on the Soleniod...as with many problems I had. I had the same problem and it just turned out to be a loose plug there, I had someone turn the key while i messed with the wires til one of them kicked the fuel pump on then it started right up Link to comment Share on other sites More sharing options...
Pete M Posted November 13, 2008 Share Posted November 13, 2008 Have you pulled off the battery terminals and cleaned them and the cables with steel wool? Link to comment Share on other sites More sharing options...
Geonovast Posted November 13, 2008 Share Posted November 13, 2008 Ignition switch. Link to comment Share on other sites More sharing options...
shelbyluvv Posted November 13, 2008 Share Posted November 13, 2008 Where in GA are you? 15 min outside ATL means nothing to me. I am up in Woodstock/Acworth. I can give you a hand if you like. Link to comment Share on other sites More sharing options...
M2 CARBINE Posted November 13, 2008 Author Share Posted November 13, 2008 Forest Park Link to comment Share on other sites More sharing options...
BLHTAZ Posted November 13, 2008 Share Posted November 13, 2008 Ignition switch.X2... Link to comment Share on other sites More sharing options...
