summerinmaine Posted October 21, 2008 Share Posted October 21, 2008 I searched, but did not find . . . I'm getting ready to replace my wiper blades. Should I just replace the blade, or must I replace the entire assembly on the end of the wiper arm? Link to comment Share on other sites More sharing options...
Pete M Posted October 21, 2008 Share Posted October 21, 2008 I just replace the whole wiper assembly. And while we're on the subject, I usually run a 14" on the drivers side and 10 or 11 inch on the passenger side. I find it helps alleviate the passenger side lifting off the glass and keeping that deposit of dirt way over in the corner (on my truck the wiper likes to make withdraws from that area and smear it across the glass). Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 21, 2008 Share Posted October 21, 2008 Unless your wiper arms are shot (no tension and/or other problems) I just replace the blades. I like the 14" Bosch Micro Edge blades personally... Link to comment Share on other sites More sharing options...
SoloCamo Posted October 21, 2008 Share Posted October 21, 2008 Why is everyone using such small wiper blades? Isn't stock 18" ? Link to comment Share on other sites More sharing options...
Oizarod115 Posted October 21, 2008 Share Posted October 21, 2008 Why is everyone using such small wiper blades? Isn't stock 18" ? haha, yeah... i have a 19" on my drivers side cause thats what we had in-stock. 18" on the pass. side. Link to comment Share on other sites More sharing options...
DirtyComanche Posted October 21, 2008 Share Posted October 21, 2008 Why is everyone using such small wiper blades? Isn't stock 18" ? Is it? The blades off my MJ and XJ that I have hanging up (incase I ever actually put them back on) are certainly not 18"... Maybe 16". So, what's the biggest that fits well? Link to comment Share on other sites More sharing options...
Pete M Posted October 21, 2008 Share Posted October 21, 2008 In addition to the fact that a factory size blade doesn't curve all the way around the passenger side of the glass, the smaller the blade, the higher the pressure per square inch. I've found it make quite a bit of difference in wiping ability on my well-weathered windshields (the highway I used to drive all the time was concrete, and concrete roadways + Michigan = lots of rock dust that makes tiny divots in the glass.). Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 21, 2008 Share Posted October 21, 2008 Why is everyone using such small wiper blades? Isn't stock 18" ? Dayem, you made me go measure. Yes, 18" is correct. I was just parroting Pete and his rusted windshield adaptations...... :cheers: Link to comment Share on other sites More sharing options...
SoloCamo Posted October 21, 2008 Share Posted October 21, 2008 I've had 19" on them due to the previous owner and although they covered a majority of the view, they were a bit on the sluggish side. Throw on some bosch microedge 18"'s and they picked up the pace quite a bit and still do a good job. I might try 17" next time to increase the speed a bit more, but I'm definitely happy with the 18's. Link to comment Share on other sites More sharing options...
summerinmaine Posted October 21, 2008 Author Share Posted October 21, 2008 Thanks! So do the replacement units fit onto the arm the same way that stock units fit? The pin through from a 90 degree angle? BTW I'll probably stick with stock 18" blades, as I don't have to worry about snow and ice lifting the blade. :brows: Link to comment Share on other sites More sharing options...
Oizarod115 Posted October 21, 2008 Share Posted October 21, 2008 not trying to be a richard-cranium but... they should be fairly straightforward :cheers: Link to comment Share on other sites More sharing options...
summerinmaine Posted October 21, 2008 Author Share Posted October 21, 2008 not trying to be a richard-cranium but... they should be fairly straightforward :cheers: Perhaps so. I've just never seen a similar mounting style before. Guess I'll just go look for myself. Link to comment Share on other sites More sharing options...
SoloCamo Posted October 21, 2008 Share Posted October 21, 2008 not trying to be a richard-cranium but... they should be fairly straightforward :cheers: Perhaps so. I've just never seen a similar mounting style before. Guess I'll just go look for myself. Should just pop out with a screw driver...then slide the new one down till it locks. Link to comment Share on other sites More sharing options...
Frankdm83 Posted October 21, 2008 Share Posted October 21, 2008 I changed my arms to a newer Cherokee arm and use the Bosch Icon blades in 18. Awesome blades! Link to comment Share on other sites More sharing options...
