xj_dummy Posted October 4, 2008 Share Posted October 4, 2008 Where is the other end of the cable? One end connects to the cluster and the other connects to the ????????????? I looked into my haines repair and it dosent say ****! Link to comment Share on other sites More sharing options...
chicofuentes0224 Posted October 4, 2008 Share Posted October 4, 2008 It goes into your speedo gear in your transfer case. Link to comment Share on other sites More sharing options...
xj_dummy Posted October 4, 2008 Author Share Posted October 4, 2008 cool, ill look in the book tonight and see if i can find a pic. thanks Link to comment Share on other sites More sharing options...
DirtyComanche Posted October 4, 2008 Share Posted October 4, 2008 On the tailshaft intermediate housing (big cone on the back of the tcase). It's fairly obvious when you get under there - there's a bunch of lines running to the vacuum switch on the back of the tcase too, but otherwise there isn't much else to confuse it with. Link to comment Share on other sites More sharing options...
Cheech Posted October 4, 2008 Share Posted October 4, 2008 There should just be a single bolt with a little metal tab that holds the end of the cable into the t-case. Once you remove the bolt and tab just wiggle it and it should pop right out. At least thats how it was on my 86, could be different on the newer models. Link to comment Share on other sites More sharing options...
Eagle Posted October 4, 2008 Share Posted October 4, 2008 There should just be a single bolt with a little metal tab that holds the end of the cable into the t-case. Once you remove the bolt and tab just wiggle it and it should pop right out. At least thats how it was on my 86, could be different on the newer models. BEFORE you remove it, clean the area well and take careful note of how it is oriented. The "quill" rotates to adjust for the number of teeth on the speedo drive gear, and if you don't put it back in the same orientation, either the speedo won't work or you'll wear out the plastic gear very quickly. Link to comment Share on other sites More sharing options...
xj_dummy Posted October 4, 2008 Author Share Posted October 4, 2008 Is there different teeth for different years of trannys? Am I going to have any trouble mating an 87 or newer cable to my 86? Link to comment Share on other sites More sharing options...
Cheech Posted October 4, 2008 Share Posted October 4, 2008 What is this quill that you speak of? Link to comment Share on other sites More sharing options...
Cheech Posted October 4, 2008 Share Posted October 4, 2008 I checked out this link http://gojeep.willyshotrod.com/HowtoSpeedoGears.htm and see what you mean by the "quill", but my speedo cable setup is way different since I have a mechanical spedo. Mine just has a little metal tab, not a fork that holds everything in. Link to comment Share on other sites More sharing options...
Eagle Posted October 4, 2008 Share Posted October 4, 2008 The "quill" is the housing at the transfer case end that the plastic speedo gear fits into. No, the gears are the same for all years of the MJ, but the tooth count changes depending on the tire size and gear ratio. As far as I know, all years used a rounded 'Y' shaped yoke to hold the quill into the transfer case. Link to comment Share on other sites More sharing options...
Cheech Posted October 4, 2008 Share Posted October 4, 2008 I will try to get a picture of mine as it is much different than the ones that you are speaking of. Mine does not seem to be adjustable like the newer ones are. Link to comment Share on other sites More sharing options...
Eagle Posted October 4, 2008 Share Posted October 4, 2008 I will try to get a picture of mine as it is much different than the ones that you are speaking of. Mine does not seem to be adjustable like the newer ones are. What transfer case do you have? I'm looking in the 1986 MJ FSM, and it's showing the "rounded fork" retainer just like the one in my 1988 XJ and my 2000 XJ. Link to comment Share on other sites More sharing options...
Cheech Posted October 4, 2008 Share Posted October 4, 2008 I have a New Process 207 AM 3. Once my camera charges I will grab a pic for you. Link to comment Share on other sites More sharing options...
Cheech Posted October 4, 2008 Share Posted October 4, 2008 here are some pics of my spedo cable setup. Link to comment Share on other sites More sharing options...
BLHTAZ Posted October 4, 2008 Share Posted October 4, 2008 Link to comment Share on other sites More sharing options...
Eagle Posted October 4, 2008 Share Posted October 4, 2008 Wow! Never saw anything like THAT before. The '86 MJ I have is a 2WD, which may be different. I'll have to see what other early 4WD XJs or MJs I can find to crawl under. There is nothing like that even mentioned in the FSM. Thank God for AMC (All Makes Combined). Every day brings more surprises. Link to comment Share on other sites More sharing options...
Cheech Posted October 5, 2008 Share Posted October 5, 2008 Haha I like that All Makes Combined :laughin: Link to comment Share on other sites More sharing options...
