mjtjnj Posted September 9, 2008 Share Posted September 9, 2008 So when I'm driving around all day, turn signals work, brake lights work, all is well. when I have the parking or headlights on, no brakes, no turn signals, no hazards! Bad headlight switch?? I never had these gremlins before I let her sit for 6 months! :cry: Link to comment Share on other sites More sharing options...
Pete M Posted September 9, 2008 Share Posted September 9, 2008 Checked your grounds? Link to comment Share on other sites More sharing options...
BLHTAZ Posted September 9, 2008 Share Posted September 9, 2008 I had a similar problem after buying my truck and it had been sitting for over a year. It turned out to be the turn signal sockets needing to be replaced in the front. Link to comment Share on other sites More sharing options...
mjdoa Posted September 9, 2008 Share Posted September 9, 2008 Just to add to what Pete and BLHTAZ said, when I got mine,the electrical system was possessed by demons. Get a service manual with wiring diagrams,find every ground on the outside especially,and clean them all. That cured all my problems. Bad grounds will cause some funky stuff to happen. Good luck. Link to comment Share on other sites More sharing options...
ICEBOX Posted September 9, 2008 Share Posted September 9, 2008 Headlight switch will do that too Link to comment Share on other sites More sharing options...
FxRacing282 Posted September 10, 2008 Share Posted September 10, 2008 GOOD LUCK :cheers: Link to comment Share on other sites More sharing options...
mjtjnj Posted September 10, 2008 Author Share Posted September 10, 2008 GOOD LUCK :cheers: I know the left front socket is bad, so I'm going to start there! LOL Pete is right about grounds!! Everything under the hood and really from the grill back is good, since I had it all apart for the engine swap. :cheers: Link to comment Share on other sites More sharing options...
