89MJComanche
Everything posted by 89MJComanche
  1. My opinion on lift is to go 3" with front coils and Kevin's off-road track bar and a set of general spring metric ton extra arch rear springs. 4 shocks of your choice and a HD steering Stabilizer.
  2. Can't post pics??
  3. Looking for rust free spare tire winch for long bed truck
  4. I got a set of cab corner rocker panel Assy paid for and cut at a junk yard about 100 miles south of Ocala Florida! Need to get these brought to Ocala by 4-16. So they can get a ride to Pennsylvania with my buddy. Can anyone help me?
  5. Just wanted to send a shout out to the guys at General Spring in Kansas City for building and shipping out a set of double military wrap 2" lift springs in the metric ton dpuble overload leaf style to me in less than 10 days! I would post a pic but you know it don't work that way! Thanks guys!
  6. Bump for a set for me too!!
  7. I need a drivers side cut ASAP and if your truck is clean I will get the passengers side too, Please be willing to ship to me from the south. I will pay!! Amswor@yahoo.com
  8. Subject says it Need a tailgate handle A LWB 4x4 auto speedo cable And a 92 gauge cluster with less than 100,000 miles on it.
  9. I have mastered a few techniques to rebuild fuel sending units. I need a few 23 gallon sending unit cores. Cores only need to have center plate that is solid enough to use. Leaky metal lines ok. Email amswor@yahoo.com
  10. Okay so I pulled the sending unit back out. And I move the sending unit by hand and the gage goes up-and-down fine! Is there a possibility that this Spectra tank could have something it's making contact with the float? I'm going now to put a full tank of gas in it to see what happens! It has 10 gallons in it right now and is reading E! Anyone have any idea how I could have messed up the sending unit simply by swapping it from one tank to another?
  11. I spent the better part of today installing a new gas tank in my 1992. Now I have no working fuel gauge! Checked the sending unit! Not sure what to do? Could this be a tank ground problem?
  12. How much for a NOS 4x4 cable?
  13. Is there a doorman part number for a 4x4 speedo cable?
  14. I need 2 sets of Comanche Emblems, and a 4.0 emblem
  15. Email me boys amsw-or@yah-oo.com Remove the dashes
  16. U got that rubber strip?
  17. I need a drivers door black body side mldg and a drivers door black rubber coated belt molding that has the black stuff peeling or that can be stripped to make it a chrome molding. I also need a passengers side door handle and a 1987 long bed speedo cable from the T case all the way to the dash. I have cold hard cash to trade! Some one pull this sh1t and I will PP u the money.
  18. Found a perfect 96 4 cyl Xj donor to make our 88 2.5 into a 4x4. What do I need to verify? Spline counts? Anything? Guy wants $300 for tranny/tcase
  19. I need the following Speedo Cable for 87 long bed with AW4 auto and 231 case Black body molding for 88 drivers side door. The lower rubber molding. 2 later model (92 and up to 01) matched pair of manual front XJ doors, complete with mirrors. 2 92-96 insurance quality fenders. Long bed tank skid Short bed tank skid Long bed tank sending unit (no pump needed) JCR offload rear Bumper with 2" Reciever Maroon Bench, or Maroon Bench upholstery that has been removed. ( I don't need the seat frame) 96 XJ sport passengers side front door panel, vinyl kind from stripped sport model. Plastic screw cap clips that hold cover on relay center. 1 1988 chrome headlight bezel in excellent condition. 1 1988 working blower motor. Spare tire Jack crank handle used to raise/lower spare tire winch. 1 1988 hood release cable assembly from the under hood actuator into th vehicle interior. 1 maroon drivers side kick panel piece by e brake pedal
  20. Floors are not rusty (drivers side previously repaired by collision shop) passengers side is Mint. And you guys are on crack $1000/$1200? DaveysJeeps.com wants that much for not running Jeep with no title! Any titled, not rusted, inspectable MJ is worth $2000. If it looks great and has $400 worth of new tires it could be worth $2750-$3000. You guys will see! Anyhow anyone want a mint condition silver short bed fiberglass topper?
  21. And what is with the shock absorber on the front of the engine?
  22. What underhood items on an 88 2.5 do I need to service other than typical tuneup stuff?
  23. I was gonna give the 5 turbines to the alloy wheel collision refinish guy and let him do them up in a medium silver metallic finish. $40 each. Worth it? I don't want AM/ wheels and want them to look new/like new after they are wrapped with new AT tires.
  24. For you gurus, gonna pull door from my 1995 plow Xj. It's a power door! If I gut both doors is it as simple as I think it should to take the 88 guts and put them into the 95 door?
  25. PLEASE USE QUOTE FUNCTION to reply! Ok, So me and my recently rich Haliburton Oil Rig Engineer cousin picked up a 1 owner 88 MJ short bed 2wd 2.5 4spd the other day. Truck was well maintained and is in fair to good condition with the exception of a previously repaired/replaced passengers side door and fender. We paid $700 for it. The bed, tailgate, fiberglass shortbed topper, and interior are near spotless. Bed of truck never hauled a single thing. The guy was a tad bit of an OCD weirdo in that he had lots of gas mileage note books and other things. In the past 3 years the truck had New brakes,rotors, mast cyl, radiator, heater control valve, clutch, throw out bearing, and many other maintenance parts. The fender and door that were previously repaired/replaced 20 years ago was was due to that shopping Cart pusher thing at the Walmart running into it without a driver. Gonna replace door and fender and paint to match. Gonna sell fiberglass short bed topper (email me) (Pittsburgh Pa) Gonna get turbine wheels reconditioned at $40/wheel Gonna put 4 new tires (205 or 215 General Grabber AT's) on it. And clean up the lower rocker stone chips/surface rust/peeling repaint, and spray both the lower rockers and the bed with good spray liner. I have a mint condition tonneau and a few other odds and ends to make a solid ultra miler 2wd out of this. How much can I make this worth with a $500 investment plus 4 tires?
