Greenjeans
Everything posted by Greenjeans
You got me thinking..š¤
I know, it takes away from the retro-80ās look of the vehicle to put a bunch of junk on the front of an XJā¦. The intent and purpose of this vehicle build was for use on an unimproved mountain propertyā¦. so form does truly follow function. And pulling the winch and lights off later is always an option. I havenāt powered up the winch or put the synthetic winch line on yet. camber looks off on my front tires. š¤
Did a little off roading this morning. š first picture with the headlights on. I had thought that the wipers wouldnāt self park when I tested them before, but you just canāt stop the switch in intermittent setting of or they stop. They do self park when turned off, so thatās good. Anyone know if just adding an intermittent controller module under the dash somewhere will give me the intermittent function? Anyway, we got some miles in the rain today⦠still missing the front winch and I have a couple driving lights for the front also. Big Hellas.. we will see if I like it with them or not.
Inching along slowly on the XJ, itās just too hot to do much on projects outside. Iām still driving 10-12 miles in it every morning to keep shaking it down. Iāll do a proper nut and bolt retorque on it after 800 miles or so. Itāll be cooler outside then. And work on the interior more.. I have been working on my China winch, about ready to mount it. New cables, solenoid box etc. new bolts and rattle-can rebuild. I had to go to the JY Saturday and there was a TJ with this Warn M6000 on it. Steel cable was toast. Pictures next to my China winch. Iāll freshen it up and hold it for a spare. It was $45 at LKQ. The dang remote will cost more than the winch cost š¤·š¼
South GA junkyard finds.
Greenjeans replied to Greenjeans's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Iād get some eBay parts off that one and just grab that front clip for fun if it was 15 degrees cooler. The yard was about empty of customers due to the desert conditions⦠-
Ok first offā¦. I canāt pull any parts. It was 97 degrees today. May hit 100 tomorrow. I would love to do it for you but I canāt. I spent one hour there today looking for a few things and it about killed me. But if you are built for the heat. These are at Cash-n-Carry in Savannah. An ā88 XJ model with low original miles. It had a 2016 tag on it, so probably accurate.. first unbroken console lid I have ever seen in a yard. and a 2000 XJ with a very nice front clip. 2wdā¦
'88 Comanche Chief (4x4, I6 4.0, Auto)
Greenjeans replied to Silverhawk1991's topic in Member Projects: Your Comanches
Looks good! -
I bought this old China winch at the u-pull-it for $25. Well $22.50 with the discount š. Scrapped the line and busted solenoid box. Made up some new 2awg wires. I ordered a new solenoid, synthetic line etc on Amazon (do Jeeps come from the Amazon now? Half of mine has š¤). Cleaned, inspected, lubed, spray painted etc. bench test is good. Just need to mount it and run the hot cable.
True to my avatar name once again ...
Greenjeans replied to NHMJXJ's topic in Member Projects: Other Cool Stuff
Very nice ride! -
WTB 1984-90 ignition lock cylinder keyed for J code keys. NC
Greenjeans replied to JeffK's topic in Wanted
I just listed a bunch of blanks (door and ignition) on the For Sale board. I know my ā86 has a replacement ignition cylinder from NAPA. The package and old ignition was in the glove box when I bought the vehicle and these āJā blanks fit perfect. Itās a GM style cylinder. It has a small bolt holding it in. The ā92 column I listed has a spring loaded tab for retention of the cylinder. Otherwise I believe the columns are the same internally. -
I just went back and looked at page 1 to see what this is. I went on my honeymoon in ā91 in an ā81 T/A that was white with a blue bird on the hood. Looks very similar! The A/C was broke and we went to Panama City in August! Good times! I hope you get that bird back on the road!
20 more miles logged today.. the good news today is I finally opened the drivers door with the inside door handle, first time since owning this XJ. And the new drivers side lock cylinder works with the same key as the passenger side and hatch. Small victory but this drivers door has been a lot of drama..also, the āJEEPā marked key blanks are cut for the doors and ignition and work! I bought a bulk pack of these key blanks so Iāll put the left over blanks on the For Sale page once I figure out how many I donāt need (not looking to get rich, just donāt need the rest). I greased the dog snot out of both window regulators so both windows work like they should! Also replaced the shift shaft seal yesterday so no transmission fluid puddle under the Jeep this morning.. We are slowly getting somewhere.. Next up: figure out how to put the minty friction reels for the seat belts in after I remove some interior plastic panels. They came from some Chevy truck at the junk yard and the buckle will work with the female end on the Chevy Sonic seats I have.. And I still need to beef up the spare tire mount for the larger spare.. Stay tuned!
New windshield day! And new wipersā¦the wipers donāt āself parkā but itās the first time Iāve ever turned them on so I donāt know if thatās normalā¦anyway got 10 mores miles in and caught a rainbow.. **I donāt advocate for driving and using a camera š.. tomorrow Iāll work on the door lock and window regulator more.. IMG_8982.mov
1986 Jeep Comanche X 2.8 Engine swap /ideas ??
Greenjeans replied to Undy MJ's topic in MJ Tech: Modification and Repairs
If you have some time to waste, check out my 86 XJ thread on the āother cool projectsā section.. I was basically in the same boat with a worn out leaky 2.8 that I swapped for a Camaro 3.4.. if you can find a decent one in a junkyard.. theyāre pretty old cars themselves now.. itās not easy or as cheap a route to go as it may seem but itās been worthwhile for me so far. If your original carb is serviceable, you are ahead of the game but most of those are junk. The Weber swap cost more than a used engine (about $500-600 for the carb and electric fuel pump). I hogged out my intake and put a free flowing exhaust in which had to help. Neutering all of the smog stuff is the best place to start if you are in a friendly state. The 3.4 is a stroked and bored 2.8 from the factory so a good option. If you have the ability to keep the 3.4 fuel injection, youād be way ahead there. I bought my Weber carb before I really knew what I was doing so I was committed to using it. It was pretty easy to set up. You also have the option to swap the throttle body over from a 2.8 S10 to your 2.8 or onto a 3.4 if you can get everything from the S10ā¦computer, distributor accessories etc But the Weber allows you to just stick with a carb to make it simple. The 3.4 came in 94-96 Camaros and Firebirds.. good luck! -
My wife is 50 so sheās not real interested in learning much about Jeepās š, however I can tell you that when we were newly married and very youngā¦and living in a tiny apartment... She kept asking me when I was going to get the āMuncieā (transmission) out of the living roomā¦. (It was all cleaned up and someone would have stolen it off our front porch in that neighborhood š)ā¦. She still says DW-40 once in awhile šbut I guess she has me trained because I know what she means.
š¤ dream about driving this thing more than I actually dew š
Rear rebuilt, reinstalled and quiet as a pin now. In fact, now I hear the exhaust drone more š. Another projectā¦. I have drone about 2700 rpm but I donāt plan to spend alot of time in that rpm range honestly. my wife and her sister were trying to come up with a name, I guess thatās a thing. And I guess āthe Cherokeeā didnāt do it for them. When I say XJ, they look at me weird because they donāt speak Jeep, and so they kept throwing suggested names out. I told them Mountain Dew or just āthe dewā would stick better than the rediculous pet names they suggested. This Jeep was purchased for use on our mountain property, weāll see if it ever gets there.. Hereās a cardboard cutout I stuck in the window, some trimming needed š last notes: still doing shake down runs, 10 or so miles at a time. Notice first mudā¦. Up next: fix leaking seal on trans selector shaft. New windshield. Fortify spare tire mount better. Put driver door lock cyl back in. Dig into pass door for lube of window regulator (brought the drivers side regulator back to life with a ton of grease). Gosh it never ends š
Removed the 8.8 rear, tire it down and found this on the inner pinion bearing. If you put these together, lay them on the bench top and press down hard on them and rotate, you can feel it āgrindingā. Do the same with the smaller pinion bearing and itās silky smooth. I checked the preload before I took it apart and it only had about 5 inch pounds rotating the yoke. And itās supposed to have around 25ā¦. tomorrow, I will put new carrier bearings and pinion bearings or at least see how far we can get with the set up. I have only done one prior and that was the front axle in this jeep. Thank goodness for YouTube.! Wish me luck⦠update.. the bearing kit wasnāt delivered today š¤¦š¼āāļø
Dash all buttoned up. 4 Cadillac horns in the garage are pretty righteous! now about that horn buttonā¦. I used to build Chevy hot rods before I took 20 years off to raise two kids. I went to swap meets went to junkyards, etc. when I found the wheel it was in poor condition with no Jeep center logo, it was missing. I cleaned the wheel up months ago, spray painted the black horn button and let it sit maybe 6 months to stabilize and dry completely. When I found it, it had that sticky rubber thing going on. While kicking around in a box of parts Iāve had for decades, I found that old Camaro horn button logo. My XJ has a Camaro motorā¦. It was fate I guess. I may swap it out one day, but for now the bowtie stays. Last Sunday afternoon I turned on an old Edward G. Robinson movie and leather wrapped that steering wheel. I used a cheap Amazon kit but itās real leather and came out nice. Another first for me but it was pretty easy. IMG_8624.mov
Iāve been spending the last couple of days putting the tilt column in and fixing some electrical issuesā¦. I put a toggle switch panel where the factory clock was. All switches work now. And I have an extra led that lights up in 4lo. And each switch has a led light when that switch is on and all work. The one marked āAux Lightā isnāt connected to anything yet, maybe an interior light will be added later. The āTQ Comvertor switch is so I can turn off the lockup torque converter if I need to.. 8.8 woesā¦. I have a junkyard 8.8 from a Ford Explorer. Iām convinced my rear end needs a pinion bearingā¦. So Iāll be pulling the rear and putting a bearing kit in it soon. I rebuilt the front axle so I have all the tools alreadyā¦Iām not looking forward to it, but it is what it is.. I also figured out why my junkyard stereo has been acting weird ever since I installed it. I had a microphone plugged into the back of the stereo for using the blue tooth for phone calls.. it seems that I had it plugged into some other hole on the back (donāt know what itās for?) and the stereo was finding a ground there or something.. unplugged that in the back and the stereo works perfect (technology is not my gift š).
Last screen shot picture I took: Spotted on marketplace. I messaged the guy and asked if heād take more than asking price but no reply š
Cool car!
Iām not at Auto Zone or Advance Auto Parts where they know me by name at this point š
Went looking for a few parts today while doing more shake down runs. Donāt ask me where I am, Iāll only lie to you š
