If you're really interested in getting air shocks instead of the bags, the Monroe Max-air MA820 fits the rears perfectly. The only reason that Monroe doesn't list them as an MJ fitment is that Monroe, in conjunction with Jeep manufacturing, has decided it's unwise to use any bolt-on device that would potentially mess up the functioning of the rear brake load proportioning valve. The length, both compressed and extended, and the mounts are exactly the same as the shocks listed as applicable to our MJs. I have them mounted on my truck, and although I don't believe that they prevent the sag quite as well as the bags would while loaded, they do an adequate job. On my metric ton suspension, the heaviest springs aren't in in use until the lighter springs let the body drop 2-3". This keeps the ride more comfortable while empty, but allows considerable sag before loading the heavier leaves on the stack. The shock overcomes this when I'm towing my boat. I needed the level ride because with the tandem axle trailer it was necessary for the even wear of the trailer tires, not to mention that the truck handles better when pulling the 4000 lbs. The Max-airs provided just enough extra lift to do the job when inflated to the max recommended running pressure of 75 PSI. The only MJ that doesn't match the length characteristics exactly is the '86 2WD. The MA820 is about 3 1/2" too long for this MJ. For every other MJ ('86 4WD and all '87-'92 MJs, 2WD and 4WD) the MA820 is an exact match with the regular shocks.
Mike
