TheBandit
    Akron, Ohio
871 profile views
TheBandit's Achievements
  1. Are those in the fuse box? Or do they hide under the dash
  2. It's a 1988 Comanche-should have specified
  3. Pete, the hazards do in fact work. As for the red, my dash doesn't have needles that point to anything it just shows the temperature symbol and behind it is a red light on the gauge
  4. Thanks to the advice in my no start thread, I have a Comanche that's running again! Now, I decided to tackle the turn signal issue. I don't have any brake lights, but the running lights work. I also don't have turn signals. When I flip the lever I don't have anything pop up on the dash- there is no annoying turn signal clicking or anything of that nature. What do you think could be the cause of this, or what should I do to test other possibilities? Also, I noticed that when I drive, the thermostat gauge is illuminated red, but the truck is not over heating. It has been around 3 or 4 degrees F around these parts lately and I'm curious if that's causing the recent flare.
  5. Hey thanks a lot, for some reason I can't get the photos to load. I got it at the shop now. It's too damn cold in Ohio right now to work on anything.
  6. So today I was driving my MJ to work and all the sudden I hit a bump and it died. There wasn't any crazy noise or anything of that nature. No steam from the engine bay. But this morning when I started it, I needed to use pliers to get the key to turn. I'm thinking that when I hit a bump on the highway that it just knocked it out of run and the ignition is so messed up that it won't try to turn over. Any ideas? Thanks!
  7. Thanks for the tip Frank!
  8. Thanks for the reply! Gonna be a rookie question, but are the XJ door interchangeable? I really don't know what parts are and aren't.
  9. It's a swb (if I'm not mistaken). I need the tam color. My biggest issue with the bench is that it is stained and has about a baseball glove size chunk missing from the driver side. I could probably get it reupholstered, but I really don't know the market for these parts- I didn't quite look into it prior- heart wants what the heart wants haha. The bed is probably my biggest issue, it's got rust coming up from the flares and probably out of reach to patch. Thanks a lot!
  10. Hello Everyone! First and foremost, I am thankful to be accepted into the club! Last week I accomplished a dream of buying a 1988 Comanche (for a whopping 600 bucks). Now behind the journey of getting it back on it's feet! I really only need to swap out a few parts: the bed, passenger fender and the bench seat! The only problem is that I cannot find them!! I was hoping you guys had some experience with this issue and would have some advice! Thanks a lot everyone! The Bandit
  11. That's a real cool design! You should make some that are close matches to original factory Comanche colors
