wannabeMJ
Everything posted by wannabeMJ
  1. thanks I just gave him a call he'll call me back with the amount for the shiping for a final price gess if you wanna do a good job u don't have a choice but spend some $$$$$
  2. well Ill be stuck I was hoping for a 4 .5 lift is there a compagny that ofers a pack of leafs with lift in it without going with a SOA? or is my only option left is longer shackle ( wich i don't realy want)
  3. why don't you try bushwacker they also make 3 or 4'' flares
  4. all ready got the sway bar and track bar will be made costum with DOM tubing will get shocks soon and for tire its a DD so ill just run 31'' I already got a YJ on 35''
  5. so Ill need to buy coils its not like G-cherokee coils on a TJ wow with a SOA ill need to lift the front 6.5'' so it means ill have to change the LCA and UCA ......... :wall: there goes the low budget
  6. how much lift will grand cherokee coils will give me? I think i read before it was 4.5'' and with a SOA in the back will the truck be level? only with these mods do I have to change the UCA and LCA? I also know that the LCA from a grand cherokee are stiffer then the oem but are they longer? I know about the brakes lines YJ lines in the front and dakota 95 in the rear remember this very low budget mods lolll
  7. love alberta for that 5% tax only lollllll
  8. quick question I also bought the insulant for the truck and I just wanna know what u used to fix it on the roof and the back wall TX
  9. well I'm on a tight schedule is as to run as fast as I can but I'm not pushing it to the point of skipping steps well trying to do my best I just hope it will look as good as my YJ lolllll no this one Image Not Found Its the same one after 2 years at working on it
  10. at wallmart they are wrangler territory 31x10.5r15 for 156$ a piece I'm gonna go for those! my truck is gonna be my daily driver so I don't realy care to much about the off road performance
  11. I just pulled mine off with my hands altought mine was original on my 86 so all craked and dried out
  12. I also went to crapytire this friday and bought the colour i was looking for I know it won't be a pro paint job this is the brand this is what its gonna look like its a little darker then the original paint almost like the ford colour
  13. i finaly got to paint the engine bay I'm getting ready for the transplant I know I'm skipping some steps but the budget says otherwise I'm still waiting on the floor pans and the rocker panel I ordered I also started working on the rear end and started wire brushing the frame so I can paint it to my helper isn't here this weekend so work takes a bit longer then expected here is a pic of the engine bay painted Image Not Found
  14. on witch vehicule would I find something that would fit that I got like 4 set of 15'' rims but I wanna go bigger 16 or 17 ''
  15. here it is now that its all stripped naked and I'm still amaze by how much rust it does not have I'm ready to tackle the whole thing I still need a few thing
  16. I'm getting ready to fix and repaint my naked MJ I striped it from everything so I can fix the rust and repaint everything (but I'm not looking for a 3000$ paint job) cheapest is not the best but........I don't mind paying a bit more then the cheapest to start : as I grind and sand every parts I don't wanna leave naked metal because my garage is not heated and cause new rust what type of primer should I use for now until I order POR 15 ? how much POR 15 do I need to do::: the engine bay, the cab floor, underneath the cab and the rear frame for the rest of the cab and the bed how much paint will I need? more tech now, I got a light blue truck and I wanna paint it ''2010 F-150 blue'' do I need to prime it before or can i just paint over it? I know my questions might not sound so clear but bear with me I'm french
  17. actually its fearly easy take this diagram that is for fog light but just replace the fogs with your electrical system Image Not Found
  18. on the same note I'm redoing my own MJ and I'm wondering what I will put as for flares I know that some XJ owners put YJ or TJ flares on theirs to widen them and cover more of the tires is that a common mod to do on MJ to?
  19. Image Not Found this is your ring gear a good way to find out your ratio is to find out how many time your drive shaft turn for a complete wheel turn roughly 3.5 drive shaftturn for a full rotation of your tire gives you a 3.56 a bit more then 4 turn would give you a 4.11 ratio
  20. sorry for the :hijack: as anybody done a full custom skid plate ? kind of a flat bellt for this or try to fit a tj or yj skid??
  21. what you live next to the canadian tire guy?? :bowdown: lucky b*stard
  22. wow thanks for the link for that price i won't even bother ill just buy them
  23. I don't seem to be able to find a place to buy floor boards for my 86 comanche I've find a couple site for cherokee's but after comparing the pics and my truck pics they don't seem to match After looking on the forum I found that you guys made your own 16 gage sheet metal then you make lines in it (with a roller?? haven't seen that at local parts store) can you guys tell me more ?? I can do the job if I know how
  24. well here is what I found after taking the whole interieur out its not nearly as bad as I tought aldo I was expecting some rust (there is no such a thing as a rust free jeep lolllllllllll) :wall: after working on trucks from quebec I was amaze to find how easy it is to work on a truck from alberta where they don't use salt on the roads so not everything is stuck in the rust that is the driver side flooring woth some holes on the flooring and I know that ill have tu cut a lot more to install the new sheet metal the second one is the passenger side witch is not as bad and I hope that after a good cleaning won't have to be replace I laso have a couple questions for you guys I bought an engine cleaner (degreaser) but it says on it to NOT put it on paint or I might damage it so WHAT DO YOU GUYS USE ON THE ENGINE BAY to take the dirt and grease out ??? second question what should I buy for flooring ?? premade flooring sheet or make my own??
  25. I called today my local junk yard today and there is no 3,4 around here so I think ill just buy a cherokee instead what year is the best for a donnor the one I was looking for is a 90?? what do you guys think
