Quarterpastgone
Everything posted by Quarterpastgone
From the album: Showtime comanche
© Showtime Comanche
© Showtime Comanche
© Showtime Comanche
© Showtime Comanche
© Showtime Comanche
© Showtime Comanche
© Showtime Comanche
© Showtime Comanche
© Showtime Comanche
ShowTime Comanche Build.
Quarterpastgone replied to Quarterpastgone's topic in MJ Hardcore Tech: Epic Journeys to Greatness
It has been rover a year with lots of other projects going on. but have bee making some progress, Fuse block mount is in. I will not to use the bushwhacker flares as i have decided on 35's. Ordered and installed Notch flares have fuel tank in final location. Front shocks fitted and mounts built. Have a total of 18 inches of tire travel. Will have the rest of the parts for the front panhard bar and front and rear sway bars for final fitment.- 76 replies
- 6.0 ls chevy v8
- 4l70e
(and 4 more)
Tagged with:
Scar-Fab frame stiffeners!
Quarterpastgone replied to krustyballer16's topic in MJ Tech: Modification and Repairs
How are these coming along, about ready fro production? -
Wheel Weights???
Quarterpastgone replied to Quarterpastgone's topic in MJ Tech: Modification and Repairs
Will all the virus stuff can’t get to my scales to check what each wheel weight is. Pete yes that is what I am looking for. -
This will sound slightly different to many. Does anyone have scale number for a Comanche, on a set of scales that tells you each wheel weight? I am trying to find out roughly what amount of weight is on the back two tires.
PM me all the info. I can get them installed that fast. -
how has it been going, any updates? -
I get it, fun always get up on the back burner for adulting. If they get cut let us know. Can’t wait for a swb set to be ready! Sent from my iPhone using Tapatalk -
Drivers seat finally got here Monday. got to build theSeat bracket yesterday and check out how the shifters felt..Factory seat cut apart for the parts needed to build frame to the sliders the new seat bracket to be built. Will have to get some pictures, had to re-clearance the tunnel for the seat to allow enough room and to keep the seat close to the stock seat height. would love it to be a little lower. But will the atlas stuffed tight this is all i will be able to get. About time to start on the wiring for this beast and plumbing brake lines.- 76 replies
- 6.0 ls chevy v8
- 4l70e
(and 4 more)
Tagged with:
any updates on the stiffeners? -
After mocking up the console and taking measurements it was time to cut the console to go into the Jeep.- 76 replies
- 6.0 ls chevy v8
- 4l70e
(and 4 more)
Tagged with:
Got some more done last night, got the reduction box shifter in and routed to keep it in the console. Here is a spare mock-up console to get the fitment and holes figured out, had it closer to the parking brake to start but the handle interfered with the parking brake that close. had to move it to the right . Will get picture of the final console once i get it fully cut and installed. Till next time.- 76 replies
- 6.0 ls chevy v8
- 4l70e
(and 4 more)
Tagged with:
Big parts finally showed up for the next piece of the drive line, My Atlas 4 got here after 7 weeks and for the most part is in, just have to find a home for the reduction box shifter and hook up the twin stick side for the case shifters.After having to run to summit to get a new trans mount to fit the adapter correctly it is in.That is my Saturday getting every thing back in and where it needed to be. Shifter cables still to come, did have to clearance the twin stick mount for the one cable after all was in at the right place.Hope to get the last shifter in tonight and the twin stick cable to the shifter also.- 76 replies
- 6.0 ls chevy v8
- 4l70e
(and 4 more)
Tagged with:
I am will be getting with you soon, have a family vacation at the end of the month then i can get back to playing with my Comanche and will be messaging you. -
Just picked up and snug too swb camper shell. All the glass is good, needs all the seal replaced, tint redone on windows and new shocks, that and a whole new paint job to match the truck. Has any one restored an old Comanche shell, does anyone now where to get seals for these old shells?
Hey y’all what do y’all think about trying to do a meet and greet for the Atlanta/ south east guys?
After much research and trying to find a measurement that i took of a 2 door xj for the location of the parking brake lever location. So i went the old fashion rout and just measured and then made the cut for the hole in the floor. Yes i read all the write ups on using the original long front cable but did not want to go that route. That will give me another good pass-thru for wiring later if i don't fill the hole just yet in the cab for the old cable. Know i am going to have to make a front cable and wait for the new transfer case to get here to finish all the shifter locations and mounting. Got the call yesterday so should be a couple weeks till it shows up. Here are some photos of the console installed and all the stuff lined up and working With the dash bezel on it for final fitment.- 76 replies
- 6.0 ls chevy v8
- 4l70e
(and 4 more)
Tagged with:
