Everything posted by AMC86Kid
Transmission and Tranfer-Case ?
AMC86Kid replied to AMC86Kid's topic in MJ Tech: Modification and Repairs
Thanks guys will do also is there a specific amount of fluid to put in or do you just fill it up to about half way ? -
Nice so where should I look for this fill plug ? -
Sounds like a plan but after I put it back together how am I suppose to fill it up with ATF fluid ? -
got it i will just put what looks to be an adequate amount also need to get some ATF fluid to dip the parts in before i reassemble -
Ok so i finally got all the t-case parts cleaned now its ready for reassembly i sure hope i manage to get it all back together correctly my question is do i just go crazy with the gasket sealer to make sure it doesn't leak no more? -
1986 Comanche problems
AMC86Kid replied to Aurelio corso's topic in MJ Tech: Modification and Repairs
If it’s a 86 it should be like mine then his transfer case should be a 207 and he should have a vacuum controlled front shift actuator on his front axle shifting it on and off he might be lucky and his hand held 4WD shifter might be loose under the truck and not shifting the transfer case at all but who knows I would jack the truck up and see what it does when you shift it does the front axle even spin ? -
ok well i managed to take the t-case apart and the inside looks pretty good dirty but the parts don't look all chewed up one thing that looked interesting was when i inspected this piece i noticed it was blue and not offset white like all the other pieces does this mean that someone else had worked on it in the past ?? -
ok so as I'm taking the T-case apart i noticed these breather holes link: https://ibb.co/W6YV106 can anyone explain what there for or if theres a link to any info online that i can read about -
Yes I do agree with J.E.E.P I'm starting with the transfer case first then decide if I’m gonna pay a shop to do the tranny right now now I have all the bolts out the T-case but the security 12 point 10mm one that’s on it, I will have to go buy a socket for it tomorrow -
Yeah I shopped around and shops want around 800 for the tranny and 250 for the T-case I'm gonna take apart the T-case and see if I can just reseal it back together with RTV so it don’t leak no more any suggestions on what type of RTV to use or will just about any type work? -
So they sell the rebuild kit for the tranny on RockAuto but does anyone know where I can get new gaskets for the 207 transfer case ? -
I have the 3 speed A904 and the 207 t-case has anyone ever rebuilt these at home with a rebuild kit ?
Ok I will shop around and see if there’s a good place to get it rebuilt I have started a new post about the tranny and TC here:
Let’s say I have a 207 transfer case is it even worth rebuilding ?
Sounds easy I will clean off all the grease so that I can actually see how to remove and read it thanks
Ok I got the tranny and the transfer case out the filler neck for the tranny where you check the fluid level really gets in the way, I was wondering if there’s a way to remove it ? Also how do I find out what transfer case I have ?
Yes I have those two things removed I just hope I can support it’s weight from the oil pan sitting on wood and that I disconnect and shifters or electrical connectors so the don’t break as it drops
Ok so I unbolted it from the rear axle now I just pull and slide it out of the transfer case, sounds easy now I have to unbolt the tranny from the front, do I start with the bolts on the flex plate / starting wheel ?
3-speed A904 automatic https://ibb.co/5MHPvHn
Finally have time to finish my Comanche any ways need to remove the tranny so i can get it rebuilt all the gaskets leak can anyone explain to me how the driveshaft gets removed from the transfer case ??
it was getting dark so i stopped but my other vent tube wasn't connected or at least i didn't notice where it was connected if you guys know where it goes let me know other wise i will snoop around when i go to clean it all out tomorrow
Well boys i got the dash out it wasn't too difficult and all i can see that i damaged was the plastic ties that hold the wires and a vent duck tube
thanks i will try my best sure looks like a lot of time oh well
Hi guys been a wile since i posted can anyone post a link on how to remove or pull the dash out i need to swap mine out with a different one thanks
