LOCK CYLINDER
Removal
1) Remove horn button and steering wheel. Refer to the
STEERING WHEEL & HORN REMOVAL article. Remove turn signal switch.
Remove key warning buzzer switch and contacts as an assembly, using
needle-nose pliers.
2) On models with standard column, turn ignition lock
cylinder (clockwise) 2 detent positions beyond the "OFF/LOCK"
position. On models with tilt column, turn lock cylinder to "LOCK"
position. On all models, compress lock cylinder retaining tab and
remove lock cylinder from housing. See Fig. 1.
Installation
1) To install, insert key in lock cylinder. Hold cylinder
sleeve while turning key clockwise until key stops. Align lock
cylinder retaining tab with keyway in housing. Insert cylinder into
housing.
2) Push lock cylinder inward until it contacts lock sector.
Rotate cylinder to engage it with lock sector. Push lock cylinder
inward until cylinder retaining tab engages in housing groove. To
complete installation, reverse removal procedure.
i can e-mail you the PDF if ya want
