Everything posted by pineymike
:D Nice project,paint it satin black please.
I've had a miller cricket for many years the original instructions say 1/4" and the ajustment on the machine shows it,There sold under a different name now but any miller dealer should know what your askin for.It runs whell on 110 even on the end of a long ext.cord,we've even run it off a too small generator and it still worked!Good luck. :D
On the cheep just weld it run it till you find the funds or a deal you can live with!
With the d35 run less agresive tires and higher air pressure and it will be fine it needs to slip some were or it will break! :D
Do soa,You'l gain lift and retain flex you can ajust your spring pack for the best compromise between ride/axle rap or ad a traction link?I did mine for max flex.But on a street/offroad truck it would have to bee a little stiffer :D
Good use of surplus parts I love it!
Thats a cool 1st comanche! was it just like that,tires,lift ect.. looking good!
Waterpump pulley clearance...
pineymike replied to DirtyComanche's topic in MJ Tech: Modification and Repairs
Water pumps are pressed together and can sometimes be slightly off[monday?] take it back and compair it to another or if you have access to a press just move the pulley mount flange.Good luck! -
Gota real kik outa that vidio but the rest of thease post were depressin'Happy 4th guys cheer up we can always beat our jeeps!!!
I'm going to be busy,busy! I try to aviod travel here in the NE! so this will be a stay home and catch up weekend?many things to do along with a bbq this afternoon! to start I'm working on dissasembling an old cabover camper[the only way to get rid of one}so I'll put most of it out for trash and scrap what I can,then I'll work on my tow rig{'89 f350 4dr 4x4}last trip the front tank would'nt draw on inspection the fule lines on top of the tank were rusted out! any way got another tank?pump ect...,thenI'll put the crabbin' boat back together{19'carolina/55hp tiller} I have to put the lower unit back on after a new w/p,hopfully by sun mornin'I'll be able to jump on the daulsport bike and head out to warton SF for some R&R.of course I'll play in the back yard with the MJ wen I get a chance![I'mg][/img]
At least it has the "good" motor
I've used that same "track bar fix" many times on well abused fords with good results.Question; wats wrong with the mini spool,I was thinking of using one in the waggy axles I'm preping for my truck? should I go for full spools or just weld the stock spiders[thats what I have now with stock axles]after all I only have the"crappy"2.8 and don't plan an engine swap? :D
YEA! I like it! an MJ workin' for a livin'!
Factory ford positraction small clutches between side gears,not very good off road w/big tires almost un noticable
need help with driveabilty problem
pineymike replied to camo89's topic in MJ Tech: Modification and Repairs
Maby this is too simple but I chased a problem like this last year I almost got into the motor I'm 50 yr old mechanic,my pop says to open the hood in the dark lowand behold the wires were bad lite show all over theay looked great but were badd ??? :nuts: -
Yea South Jersey a differn't state of mind than" joisey", The hood was like that wen I got it along with a ton of other stuff I blacked out but everyone around here likes that part so I left it for now?? :brows:
Hey! thanks pete I got a envolope the other day as I opened it I'm scratching my head thinking who? do I know in MI???any ways nice thanks again.
YO! awsome build dude!
Long bed bobed is corect,go to mj projects for more pic's under yard truck turned rock crawler.
raush creek,'07 before big red!
Yard truck turned rockcrawler
pineymike replied to pineymike's topic in Member Projects: Your Comanches
The bed was only shortened after the rear wheels,between the wheels and cab is stock,I was carefull to cut where the body lines would match and only the rear most bed mount was eliminated,I have a small 110 volt mig that I welded it back together with about 2" at a time skipping 2" in between coming back to fill in later after it cooled down.More body work will be done,but not to any extreem,I won't trash the body either! I also did a spring over in back eliminating a stiff add a leaf installed by the previous owner.That alone added a lot of flex! at the same time I removed the rear shocks some of the guys around here run xj's on the street without shocks? seams to work any way I also removed the front sway bar and boxed the front control arms for added strenth.The truck allready had 3" lift on it when I got it,other mods include the battery moved to the bed the factory rollbar moded for added strenth,welded front&rear diffs,welded axle disconnect,removed all emmsions controls& unesscary vacume systems from engine{I wish I had before and after pics of engine} Future mods include Waggyd44's,bigger tires,new red paint -
My curent driver is a '79 cherokee, 455buick/4"lift/detrout inrear/openfront/panel rear doors/'64 gladiator front clip&rear flares/33" mt's. I also have a 55 willys cj5 w/historic plates 350 chev/t18 4spd/4"lift/full cage/rear detrout/33"at's. I've owned the cherokee for15+yrs, I lent it to my brother for 6or7 yrs and it came back with the buick it actualy gets better gas milage than the stock 360! I've owned the willys longer probly 20+ it's at times been my daily driver{so I could keep it!} and always been my favorite! it's currently under going its 4th reconstruction.I also have a '80 j10 360 auto/4"lift runs doesen't move have collected '90 360/auto/rust free bed&front clip almost enough to start reconstruction plan to match the look of the '79 cherokee including the gladiator grill,way back burner jeep project '57 cj5 225 v6+ most parts to reconstruct already colected plan to keep closer to stock w/power stearing/11" waggy brakes/4"lift/33"tires/stock jeep roll bar. Other non jeep vehicles include; '89 f350 4dr 4x4/3" lift/36"mt's/460/5spd{tow vehicle} '77 f150 4x4 300 six/t18 4spd/35"hawgs, '66scout stock 4x4/front&rear lockers,'63 2wd scout{only 2wd} wifes car;'96 explorer 5.0 awd.post pic's later!
[I'mg]mesure twice cut once[I'mg] Sawsall![/img]rite to the shackles4:10 gears seam to work just fine I've personally have good luck with{crappy}2.8's and have a nack? for tuning every once of power from them!
