My current cluster has full gages except for tach (has large fuel gauge that every one of my friends make fun of) if I change it to a tach cluster what do I need to do to get tach working? Is the cable there and it's plug and play or do I need to run new cable?
smithe1811, as you know I live a few towns away in Mt Top. My 4.0L has a hell of a time keeping up 45mph going up Rt309 from W-B to Mt Top. I could never use 5th barely use 4th. So I could only imagine your pain in our area.
My AC pulley (I don't have AC but the pulley in its spot, top left pulley) froze up on me. Is this only a dealer part? I tried Advanced auto and PepBoys and neither have it.
Here is a different model. Will this work?
http://www.autopartswarehouse.com/detai ... 7072S.html
Also, found a place that will rebuild them.
http://www.tristarrradiator.com/
I am trying to take the front driver bracket off the MJ bench and buckets so I can swap them (bucket bracket badly rusted) I can't seem to get them apart. I drilled out the stud but no luck. Is there anything else holding it on?
Soryy about the hi-jack but on part #19 the smaller tube..is this the air vent? I think when I filled my tank and had it parked on a side hill with the tank on the low side I was dripping fuel. Is this hard to change out?
OK. Thanks. Just ripped the original rubber mat out to see what the floor looked like..it was soaked....not too good...but I'm sure there are worse. just need front pans, seat area is good. Figured while i was in there I would check it out.
OK. Please bear with me. Is it the bolts under the cover or the bolts that hold the cover on that you are talking about? The cover I am talking about is the one under the console that lets you get to the tranny. :D
Does the weather stripping that is on the door pillar go all the way around to the roof/back of cab? When I'm in my truck I can see daylight thru the top of the door. The door has weather strip on it but the weather strip that is on the pillar doesn't continue and I get alot of road noise not to mention all my heat escaping.........
