thanks for the input guys. just went out and put them up against some rocks and they held up well. i ended up actually on accident letting the whole truck fall onto one and it didn't move so mission accomplished!
oddly enough when mine started whining i unplugged the connector to the alternator and it went away. i immediately knew after that it was the alternator. low voltage seems like an obvious alternator sign too.
good luck
i can jack it up from any part of the slider, jump on them. they are very solid. they are mounted with four bolts to the frame each and four bolts to the pinch seam. all the steal i used was 1/4 inch so it won't be breaking probably ever
what i meant was most sliders stick out and act as steps making your jeep wider and more susceptible to rocks and such. i didn't lose any ground clearance. the frame rail is lower than the arms that come out.
here is what i fabricated for my rock sliders. wanted something that wouldn't sacrifice width or height. here's what i came up with. let me know what you guys think.
its not a bolt on job. the top mounting is the same but somewheres in the middle a couple studs are missing for the 97+ grill to fit bolt in. you need to somehow secure the bottom of the grill to the radiator support. i used long bolts and big fender washer on the fiberglass header panel. the wiring needs some altering but is for the most part close.
vs
didn't do the fenders but i like it anyway. got the whole setup for 30 bucks off a rollover victim. the grill was cracked in like 4 places but fiberglass fixes that.
i have the same weak spring issue. i am about 160 and drop the truck 2-3 inches. i consider it a blessing, soft springs = good flex. i was thinking about getting air shocks so i can adjust stiffness if i ever had a load but its hard to get long enough air shocks
yea thats why i said 8-12, haven't really looked into it a lot, i plan on ending the bed just after the shackle mount, also ii may 4 link it. not sure just yet cause its still my DD for now
Anyone have any pics of their bed chopped? I want to take 8-12 out of the rear and then weld the lights and such back but wanted to see what it would look like, and i have a short bed
tthanks in advance
http://mrmontez2000.proboards70.com/ind ... 1177296972
unfortunately i cannot find the picture of the finished product but all the cracks are fiberglassed in and painted obviously. my rot was so bad in the drivers floor i had to just about replace the whole thing
good luck
Hey guys I'm new to the site but noticed a lot of lifted rigs out there. i have an 88 mj 4.0 5spd 4x4 locked rear lifted 2 inches with 31 inch bfgoodrich ta ko's. anyways i was seeing if anyone has any pics of how they trimmed the fenders, i just wanted to see a few examples so that i know how far to go with mine. thanks in advance
